- 2:18 AM
- Jan 7, 2016
- PIlot Mtn, NC
Drill and timesert
Guess I need to cry once and get a kit.
Drill and timesert
@jakethesnakeHere's how you can mount a 372 wrap
To a 268/272View attachment 298470
This bottom fastener is in the correct location you just have to add the second hole.
And not use the other 2 locations
You just have to bend the down tube to fit the recess
Both fasteners line up with the existing holes
I relieved the bottom corner to make it easier to fit.View attachment 298472
View attachment 298473View attachment 298474
The brake flag is too tight
I'll try some different versions.
@High octaneHere's how you can mount a 372 wrap
I imagine that’ll clean up pretty good.I'm finally joining the red side! I've decided for 28 inch bars I'd rather have a pair of 272's instead of a pair of 372's. She needs rings, maybe a piston and some seals, a top cover and some bigger dogs, but I finally have an elusive full-wrapped J-red 2-series! There may be a chance I'll have to cut her loose, but I'm thinking it's a keeper.
View attachment 312017 View attachment 312016
View attachment 312014 View attachment 312015
Yeah, it looks to be pretty low use so I'm hoping it'll clean up fine.I imagine that’ll clean up pretty good.
I would respectfully like to differ on the 181/early 281's not sharing pulleys with their smaller counterparts: According to Jackssmallengines, pulley #503102402 is used on the Husqvarna 61, 266, 281 and 288.Nice job @Woodslasher , but yes these pulleys can drive you nuts. A look into the dusty archives I have can fill in some of the blanks. Lot of the confusion is because the electronic info available to everyone in incomplete.
The short explanation is that there are 4 Husky pulleys and 2 Jonsered pulleys. .
The first pulley is the small post/small ID pulley that came out on the 162SE, white top 61 and the early Jonsereds. The part number is 501 520 701. This pulley was used longer on the Jonnys than the Huskys. Jonsered use this pulley until 1990, so pretty much all of the twin coil Jonnys will have this pulley.
Husky went to a larger ID pulley for the 266/brown top 61's; part number is 503 102 402. The next change for Husky was due to the change to the deeper air injection starter that used the larger decal, this is where the long shank "5 ring" pulley was introduced and is commonly called the 272 pulley, and was also used on later 268's. Part number is 503 102 405. This causes some confusion on the 268's as the early XP's with the small decal starter retained the 266 pulley. The missing link in here is the 3 ring pulley that was a short lived deal I think due to a flywheel change. Not sure on the dates, but may have some documentation somewhere. Part number is 503 102 403 and it is NLA.
Similar story for the newer Jonnys; 625, 630 and 670 Super II and the 670 Champ. Pretty much all the single coil saws, starting in early 1990. Part number is 503 432 101 and it is also NLA.
But as you can see, for the most part, the pulley doesn't have to match the saw, it has to match the starter housing. Complete starter assemblies can be swapped between saws. Possible that some pulleys can be modified to fit in different housings, but I've never tried anything there.
The 281/288 uses a different pulley, and it didn't change when they went to the large decal starter.
Bolt right on?@Husky187
Here's what I wanted the 576 wrap forView attachment 337268
It's my filthy truck saw a 266
I use this saw more than anything I have.
NopeBolt right on?
@mrxlhView attachment 337275 View attachment 337273 View attachment 337274 View attachment 337271
Nope
But all fasteners line up with existing holes
The down tube has to be bent towards the saw and ground or smashed thinner to clear the clutch cover
And the back bottom edge needs trimmed off to fit into the tank
Recess but the fasteners
Line up perfectly.
The 372 wraps are less work.
