Husky 162/272--Jonny 630/670 project thread.
Johnmn
7:53 AM
Minnesota
And the one piece coil saws had 2 different cranks and flywheels. One with a cast key and one without, if I remember correctly you cannot interchange flywheels. I believe the crank is a larger diameter on the one with a separate key.
8:53 AM
Here's how you can mount a 372 wrap
To a 268/272IMG_20210616_192721.jpg
This bottom fastener is in the correct location you just have to add the second hole.
And not use the other 2 locations
You just have to bend the down tube to fit the recess
Both fasteners line up with the existing holes
I relieved the bottom corner to make it easier to fit.IMG_20210616_195820.jpg
The brake flag is too tight
I'll try some different versions.
Ronie
8:53 AM
NC
To a 268/272View attachment 298470
I relieved the bottom corner to make it easier to fit.View attachment 298472
View attachment 298473View attachment 298474
Looks good, this guy here did it a little different.
Ronie
8:53 AM
NC
I think your way would be stronger unless you welded the pieces together on the way that guy did his.
8:53 AM
Plenty of clearance for bar nuts and top cover.
davidwyby
Rural desert logging
5:53 AM
Extreme Southeast CA
I have a 162 parts saw...well, case and tank...how much interchanges (or doesn’t) with the rest of the saws in the series? Seems like most should.
smokey7
8:53 AM
Detroit
Yup most stuff does. It's close family with a Jonny 630 for a top end.
davidwyby
5:53 AM
I might have bought it if I had seen in time and had a saw nice enough to put it on, ha!
Flip
8:53 AM
PIlot Mtn, NC
What is the best way to fix egged out top cover screw holes? I'm looking at my 2 series projects and all the crankcases have at least one hole that needs to be repaired.
