anatoli031585
Active OPE Member
- 1:32 PM
- Dec 7, 2025
- Buena NJ 08310
So yes the 030, 031, 032 vented caps came in a few varieties, can no longer get individual own parts, but you are able to get proline am replacement cap assemblies, we know this...
Well paying $30+ for an am cap on a saw I paid $50 for doesn't sit well with me and I haven't seen anyone do this so I figured why not. Today we drill!
So the idea was to drill a single hole in the tank, fit a grommet, run a modern Stihl vent of a line that was both concealed like the fuel line, under the top cover, and routed into the carb box which is the cleanest place on the saw.
So I take the saw apart, empty the fuel tank of some but not all the older fuel. Figuring that no matter how careful I am, drilling would get in the tank and I would use it to help carry them out before flushing with fresh. Picked my spot I thought would work far enough from the edges and drilled. Lol, my first mistake.
In my exuberance and in a rare lapse in my standard regiment (pre plan every step, measure 5x, cut or drill once) , attempting to bang this out in 15 mins that I had available, discovered my chosen spot was less than ideal. There I am drill and blow (the drillings away) nice and slow, wondering why its so thick, haha, guess I have to come back to this one, its no longer a 15min possibility....
What you're looking at is this genius drilling partially into the fuel tank and partially into the cavity for the machine screw that fastens the 2 tank halves together. Doh!
The grommet I wanted to use had a wide profile so that placement would have been perfect, or so I thought, in actuality, I should have gone over 1/4"-5/16" to the right, then down 5/16"-3/8". I learn later this position I've drilled gets more troublesome....
So I'm back from whatever chaos I that demanded my attention now committed to the task. Well options are now limited so lets see here what I've got to straighten this out. Interesting side note: the event that got me into Stihl saws has paid off again. I was at the scrap yard one day with a load when a truck having an awful time attempting to unload the massive dump bed about 30 yr dumpster size kept pulling up, backing up fast, slamming on the brakes next to me. Finally the load released and there was a perfect compacted metallic rectangle next to me. Oh the wonderful things contorted and mangled in that magnificent quagmire! Like someone's entire shop all jammed into a steel casserole. I immediately noticed several stihl saws. The yard had just instituted a new policy prohibiting anyone from buying things anymore, after a storied history of charging you 4x the scrap price prior to that for anything you might want.... I was determined to save what I could, using my truck to block the sight lines, I had 30 seconds. I saved an 024 avwb and 028 wb. The others were top far in, damn! I had a single additional opportunity to grab a very heavy metal case and hid them on my truck. Long story long, the case had about 80 lbs of tiny brass fittings, of which, I took a little of every type to keep with my small engine stuff, glad to have it on hand now years later.... Dont mind the 064 in the background, she's an attention hoe.....
So I find a nice long elbow and the epoxy, convinced that it will just be easier to fill in the screw cavity. If I ever have to split that case, then I figured ill get a parts saw tank long before that day comes...
But wait, isn't that a large cavity to fill and seal the tank from pressure changes, yes, its true...
What to do, hmmm, I started ripping of the cotton applicator tips I have for precision cleaning, dumping them into the epoxy mix, as I pulled them apart a little, then mixed it in, leaving some to the side without any.
Continued on next post so I can attach the other pictures........
