- 11:58 AM
- Jan 24, 2018
- Extreme Southeast CA
Looks good, this guy here did it a little different.Here's how you can mount a 372 wrap
To a 268/272View attachment 298470
This bottom fastener is in the correct location you just have to add the second hole.
And not use the other 2 locations
You just have to bend the down tube to fit the recess
Both fasteners line up with the existing holes
I relieved the bottom corner to make it easier to fit.View attachment 298472
View attachment 298473View attachment 298474
The brake flag is too tight
I'll try some different versions.
My way took 5 minutesI think your way would be stronger unless you welded the pieces together on the way that guy did his.
That does look good, I might do that to mine.The plastic flag works fineView attachment 298537View attachment 298538
Plenty of clearance for bar nuts and top cover.
I don't think that will last to long.
Did you get it, it sold?
