- 12:46 AM
- Jan 22, 2022
- MO USA
Well that's no fun, you have a generator?Lost power at my son’s house last night about midnight. Still no power.
www.680kfeq.com
Enjoyed reading of veto of 1/2 billion$ in spending. If only it could've been more than 1% of the budget. And woodent that be intra state rather than inter state?The first I have heard of this :
Gov. Parson says groundwork needed before HW 36 becomes I-72
Photo by Brent Martin By BRENT MARTIN St. Joseph Post Gov. Mike Parson says he vetoed the money to study whether U.S. Highway 36 should become I-72, because the proper groundwork hasn’t been laid yet. Parson usedwww.680kfeq.com
My bad! Hanibal at hwy61is one end of existing I -72 , so getting Federalies on board wood be needed to buy up all those acres of good crop land along there.Enjoyed reading of veto of 1/2 billion$ in spending. If only it could've been more than 1% of the budget. And woodent that be intra state rather than inter state?
I am not sure it really needs changed to an interstate, it’s already 4 lanes from St Joseph - Hannibal The cost will be exponential & I can’t see a lot see a benefit. As you stated there will have to be a tremendous amount of ground bought up & I can’t see a lot of those folks willingly selling their land.My bad! Hanibal at hwy61is one end of existing I -72 , so getting Federalies on board wood be needed to buy up all those acres of good crop land along there.
Looks a good way to dull a bladeCuttin' the good stuff (not) here this morning....View attachment 385542
Yes, and it's not good for my blood pressure neither......Looks a good way to dull a blade
Trying to fix the wheel bearing on the mill here but the back race doesn't wanna come off... advice please....what am I doing wrong.
My c-clamp is not too tight, just snug enough to keep the puller jaws from slipping off.
I tried tapping on the head of the puller, and also was able to tap on the race from behind....but it's not moving at all.
Any way to cool the axle and heat the race?
The whole thing got way hot when I ruined it driving home, I thought maybe all that heat caused the problem.
I hate busted stuff....
Ok, thank you boss.Slit it almost all the way through at an angle like this with a cut off wheel and then split it with a cold chisel. You do it at an angle so you can get closer to the sholder.
Ok, thank you boss.
I think that'll work.... hopefully I don't set the barn on fire....
Definitely... there's an abundance of kindling around an active sawmill.I'd have the hose on standby.
