Workshop
10:37 PM
Nixa, Mo.
Might have a bit of corrosion in there. It certainly doesn't take much to foul things up in those.
Oh yeah,
Morning everybody.
MACHINE
11:37 PM
Broken Bow, Oklahoma
One problem overlooked on a thermoquad or quadrojet is throttle shaft area worn ,, you can drill them out and brass bushing them to stop leak .
Sent from my SM-G955U using Tapatalk
moparnut88
11:37 PM
US
One problem overlooked on a thermoquad is throttle shaft area worn ,, you can drill them out and brass bushing them to stop leak .
Spot on. All carter carbs are that way.
67L36Driver
10:37 PM
This pump can have other uses, like on SIL pontoon boat that sat out last season. [emoji57]
And the ‘40 Ford, ‘62 Corvair.
67L36Driver
10:37 PM
What I want to know is; why the chronic failure of the kill switch on the 266se and now the J’red 630. [emoji2955]
And, the fuel and oil caps; some have rubber washer and some have ‘O’ ring. The 266 has both!!! [emoji15]
WKEND LUMBERJAK
10:37 PM
West of Kansas City
Is it a slide left and right or a toggle switch.
moparnut88
11:37 PM
US
Out and on the road. Taking the old d7 cat to her new home in awols nick of the woods.
67L36Driver
10:37 PM
Switch on the 630 checks good. Open & closed circuit. So it has to be problem on coil end of the wire. [emoji848]
Most all the parts for the 266se due in today. [emoji1696]Send that pup back home. [emoji106]
