67L36Driver
- 5:05 PM
- Jan 18, 2016
- Missouri
What I really, really want is retrofit fuel injection. Throttle body would do fine. [emoji106]
That’s blasphemy on a 67....lolWhat I really, really want is retrofit fuel injection. Throttle body would do fine. [emoji106]
What you clean yours with??Spent the afternoon giving the Jonsered ‘the dip’, and the deluxe rewind starter overhaul.
No more droopy handle. [emoji6]
Some ignition wires need new tape.
If lived close I'd bring you some degreaser that is bad ass ,The purpose of ‘the dip’ is two fold.
One is shiny stuff sells and the other is I get a detailed look at the condition of all the important parts.
Plus, a clean air cooled engine runs cooler. [emoji106]
It's called ol blue , best stuff I ever seen
Sent from my SM-G955U using Tapatalk
Janitors local supply,Where you get that at? We use the purple ko degreaser in 5 gal buckets.
Broken Bow Oklahoma.
You can use it in ultrasonic cleaner also
Tell your woman she can use it for her jewelry [emoji6]I’ll have to look that stuff up. And that’s one thing I’d really like to get is a ultrasonic cleaner.
I'd have to buy her some jewelry first, I suppose.Tell your woman she can use it for her jewelry [emoji6]
You could go down through the bowl vent and try bumping the float.Post 'dip'.
Fixed the 18 ga ignition wires. All the AV mounts are sound. Kill switch still don't work. Not cluttered with faceless stickers.
I suspect the float or the float hinge pin is causing the valve to stick shut.
With that being said, it would still be a good idea to remove the air horn. At least just for insoection.
Ill pull the air horn so you Qjet experts can give it a look.
