- 10:20 PM
- May 30, 2022
- NW MT
that van has a 60 upfront? thats badass
I have found the latex mechanic’s gloves really help working outside in the winter.1st test run: Bad exuahst leak. Turbo to up-pipe flange. The tolerances are so tight, the turbo clamp can't be relied upon to cinch it all together.
Those kc turbos nerds only show one method with everything out of the truck. It didn't work:
I walked away from the vehicle when I thought of lighting it up with a 12 gauge.
After rest, an idea came to me:
Get a camera back there and see where the misalignment is, with the turbo clamp removed. It was maybe at most, a 1/8" misalignment at the bottom.
Nobody has mentioned this anywhere, but what I ended up doing was fishing a ratchet strap back there around the back side of the up-pipe flange. Hooked one end to the rear engine hoist eye, the other end to the front tow hook. As I cinched er down, I tapped on the up-pipe flange with a 4ft breaker bar. She went home!
To work on everything was aweful mechanic yoga:
Place tools on woodstove to get them warm to the touch. Race outside and have at er before those tools go back to single digit temps.
Jam forearm between turbo and firewall till your bleeding. Rest forehead on lip of firewall. Laying completely over top of engine, rest sternum over top of alternator.
Bolted the turbo clamp and then removed the ratchet strap. Massive exauhst leak gone.
Misalignment:
After ratchet strap + breaker bar taps:
Was so tight back there, I needed dexterity of bare hands.I have found the latex mechanic’s gloves really help working outside in the winter.
Snow never melts on your hand to make it cold
I much prefer working on the 6bt cummins. Everything is accessible from the left and right side, less bllsht electronic sht too.I have fought that turbo to up-pipe flange before myself. It is a pain in the genitals for sure. I also have fantasized about harming my truck mid-project as well. Told my wife once that i wanted to parking the *f-wording thing on a brush pile and light it on fire.
I thought you liked the general tires better?GM is running a buy 3 get one for $1 tire promo.
So the old shīťbox got some new hogs.
View attachment 474335View attachment 474336
Plus put the snows on my wife's Terrain and Mom's Buick.
New timken bearings on the grip pros. Put them bearings on the wood stove at 300 deg. F. Differentials were outside at five below zero.
Some light assembly oil and them hot bearings went onto the chilly carriers like butter.
No hydraulic press out here so I tried out the "smash pucks". They're machined from some sort of rugged plastic. They have a recess for the carrier housing and center themselves tightly inside the outter bearing race, sitting perfectly on the inner race.
Them smash pucks work better as a pair so the bottom of the bottom of the differential is supported. Could also be used in a press.
@redline4
This plug wrapper tube is rattling
What gives?
Fanks
View attachment 474819View attachment 474820
