First time porting
XP_Slinger
They’re Just Saws
3:21 PM
Central NY
Subbed...good thread guys.
Are you going to cut base and squish or delete the base gasket?
David Young
Safety First !!!!!!
3:21 PM
vt
I measured bore, then put peice of paper in cylinder to match curve and traced port then pulled paper out and put it around piston to see where it was on it, added my 65% then layed paper back on piston to check. Does that sound about rite?
Sent from my SGH-I747M using Tapatalk
Yep you got it
Little detail just thought I would mention it.
merc_man
merc_man
3:21 PM
southern ontario
Yep you got it
i apprexiate it. Im like tripple checking stuff to make sure i dont ruin anything. This is a ausome learning experiance. Im not even done yet and cant wait to try tear into another saw.
merc_man
merc_man
3:21 PM
southern ontario
i started opening the entrance to the transfer port. You can see on the untouched side how restricted it would have been. Sure this will help improve air / fuel flow.
XP_Slinger
They’re Just Saws
3:21 PM
Central NY
Looking good. You're going to love those removable transfer covers when you get to the upper transfers.
merc_man
merc_man
3:21 PM
southern ontario
not sure im gonna touch the upper transfers yet. Might be a little advanced for my first time. Gotta do more research on them first to undderstand how exactly they work.
merc_man
merc_man
3:21 PM
southern ontario
For a base sealant for a gasket delete. What do you all use?
merc_man
merc_man
3:21 PM
southern ontario
Hondabond, yamabond, dirko, 1194, ...I get motoseal at the auto parts store. Works great
Ive got some of this seal all. What ya think about using it or get a better one like the names you mentioned.
David Young
Safety First !!!!!!
3:21 PM
vt
this is what you want its easy to clean up all the dirko hondabond etc. are a little tougher for clean up but work great on clamshells in my experience.
I think the seal all is kind of a glue, Idk if I would use it. but I have never tried it.
David
3:21 PM
Ok. I might even have some permatex will have to look
Most common permatex is silicone based. It's been said that silicone will soften over time when used in gas. If it's not a big deal, get motoseal. Otherwise, silicone is probably fine
3:21 PM
The stuff David showed would be perfect also. Might be cheaper too given the smaller sized tube
merc_man
merc_man
3:21 PM
southern ontario
Not sure if this is any good. Dont say anything about gas.
Will see if i can get mpto seal in ontario. Some stuff is hard to find over here.
