merc_man
merc_man
- 4:52 PM
- Feb 24, 2016
- southern ontario
All i did to the saw was gasket delete and widen the transfer. Muffler was already gutted. I added the pipe to muffler. Just wanted to try and keep it simple for the first time but really not much for gains. Might have to learn more about timimg and how to determine how much you can rais top of ports.So in the interest of learning, lets talk about everything that you did to this saw. What was stock timing? How much did you raise the transfers, how much did you raise the intake and exhaust?
Just dont overdo the porting too quick. Its easy to wanna grind away!!All i did to the saw was gasket delete and widen the transfer. Muffler was already gutted. I added the pipe to muffler. Just wanted to try and keep it simple for the first time but really not much for gains. Might have to learn more about timimg and how to determine how much you can rais top of ports.
The intake port the ring ends are close to the edge so never wanted to widen them.
I went about. 65% of the bore.Just dont overdo the porting too quick. Its easy to wanna geind away!!
I been reading it since beginning. Lot of good knoledge on ther.If I may humbly suggest the "porting theory" thread on here. It's a long read at this point (38pages) but I learned a TON.
No.I still havnt been able to find info on how to determine how high you can take an exhaust port or intake port. Is it a certain amount of degreese for a max on degree wheel.
Thanks. That helps a little i think lol.No.
Exhaust roof does three things. It determines when compression of charge begins, it determines the amount of trapped volume, and it determines when combustion pressure is vented.
There are some general rules on this. In my mind you want it to open at the very point where pressure from combustion becomes close to parasitic drag losses. That's the theory at least. The actual amount that's best for any individual saw varies because of design and stroke.
A lot of guys use a rule of thumb of exhaust opening based on displacement for a worksaw. 105 on 50cc, 103 on 60cc, 101 on anything larger. But no one fits all in this game. If you have too much compression, somethings you want a higher roof. If you want more rpm and less lugging power, sometimes you want a higher roof. Etc...
The more you learn in this game, the more confusing it becomes. I hope the above helps.
