junkman
Crush it
- 8:09 AM
- Jan 3, 2016
- pacific northwest
I had to cut some railroad ties ,yes my chain is dull now .
I prefer hard woods let a saw work like is stolen. I run my piped saws in hard wood just cause I can as we're others at gtg run race chains and won't touch anything big or hardwood.The timber is seasoned rock hard eucalyptus.
We dont have pine, or any softwood to make the saw look fast![]()
No worries!Hell couple good swipe that'll cut
Jesus H. Malmsteen gotta put this out there. WTF.....
Looks like half the chain is backwards. One half the chain faces one way the other half faces the other way
Had to tell from your photo of the chain. That grinder has a fixed head angle, probably at 60°, which may be different from what you hand file, but should still cut. Couple of questions:
- Did the color change on the cutters as you ground (red, blue, or black)?
- Can you hold a filed cutter next to your ground ones and see a difference in the edges (top and side)?
A light touch on the grinder, and a well dressed wheel, can address both of those issues (if present).
I looks like you may have taken the wheel pretty deep into the gullet, where you end up sharpening / shaping with the side of the wheel instead of the rounded edge. Again, hard to tell from the photo.
Philbert
