Dull Chain Thread...
Brush Ape
Direct Connection
9:52 AM
Metropolis, Il
Experience is the best teacher. You know with a chisel, knife or any manual cutting tool, a dull tool is a dangerous one. When you have chain spinning 90 MPH, how much is that hazard amplified?
Sometimes it is best to witness a failure to see what won't work. It's fun stuff to post chainsaw vids on youtube....but; I'm sounding off here for a renaissance in chain sharpening. If you're a member here at OPEforum, you're already a 1%-er and more than likely, you're part of the cure and not the problem. lol Especially in this here, "Just Chains," sub-forum that goes twice.
The best modification you can make to increase the performance of a chainsaw is a properly sharpened, tensioned and lubricated chain. That's neck and neck with carb tuning. Let's have a look at some dull chain vidjas and have a little lol.
junkman
Crush it
7:52 AM
pacific northwest
Just got done sharpening 7 chisel chains that most guys would have kept using because they still cut half ass ,once they lose the edge at all i swap them out . No reason to run a dull tool , i kind of wonder how sharp most guys cut with ,and what is acceptable to most guys when cutting,i have a stihl bar with a lot of use now and the paint is not burt off from running hot ,i see some guys bars,you can tell they run dull chain by the paint missing.
9:52 AM
Southern illinois
I'm with you. When the chain start's to fall on it's face then it get's touched up.
HuskyHill
10:52 AM
pa
It only takes a few minutes to touch a chain up and keep safe and productive. If you let it go to long it is much harder to put an edge back on and sometimes takes a couple sharpening s to get it back to where it should be. I sometimes cut in areas where there were old pastures and unfortunately "find" the occasional nail or fence wire grown into the tree which does a job on the chain and it's never fun to put an edge back on after that.
Canadian farm boy
“Normal” people scare me.
10:52 AM
Ontario, Canada
I agree. It only takes a minute or two to give each cutter a couple quick licks with a file. I usually do this when I've stopped to fuel up the saw again. (Helps extend your break as well). Now if I hit something in the wood or put the chain in the dirt I switch out the chain. The damaged chain will then get sharpened on my grinder.
junkman
Crush it
7:52 AM
pacific northwest
I just grind em ,and have some fresh ones ready to go if hit something ,keep having chrome buildup on the side plate sometimes for some reason ,looks like a double cutter till it gets used once .I never use a file on a work chain ,i hit too much rocks and stuff to put that much time into a chain .If have to use the dogs for anything but lining up cuts ,your chain is not sharp ..404 2-1-16 269.JPG .404 2-1-16 272.JPG .404 2-1-16 270.JPG
RCBS
Redneck Savant Extraordinaire
10:52 AM
Ohio - The hilly part
This is what I do. Few strokes every time I fuel the saw. Over the years, I have become fairly proficient with a hand file...practice makes mediocre they say! One of these days, I'll learn to keep the tip out of the dirt.
