Building a Garage
Marshy
WFO Cutting
2:26 AM
Mexico NY
I want to build myself a detached garage, probably 32x40. I've been considering a pole barn structure with 12' ceilings with plans to do a 12' lean-to on one side. The problem is, wife wants it to look like the house so brown architectural shingle roof and clap board cedar siding... looks like I'll have some homework to do...
Any advice is welcomed.
2:26 AM
Not sure what your local codes are, or if it matters in your case. The stick built / floating slab isn't a bad way to go if the edge of the slab only needs to be 16 or 18" deep. More than that sucks to form and keep the sides straight, as most form stakes are only 24" long, and it's tough driving in longer ones unless they're steel.
Polebarns go up quick, but you have a $60 post every 8'.
Either style can be sheeted for your siding/shingles without any extra work
Marshy
WFO Cutting
2:26 AM
Mexico NY
Yes, a twin post lift is in the plans. Probably wont get radiant though, just a wood stove likely. I just did a Froling boiler this past spring in the house and haven't even had a chance to really use it. I doubt I could head an additional 1000+ sqft, not withough additional thermal storage. Idk, better to have it and not use it then need it and not use it...
Good advice on the slab footer, I'll ask my code guy. They may want it at frost line which I believe is 48" here. I have a good friend around the corner who stick built his garage so maybe he remembers his footing... he built a 10' wall on 2 courses of cinder block. That might be an option as well.
srcarr52
2:26 AM
Iowa City
12’ height isn’t tall enough to install a twin post lifts that can lift a truck to tall peoples working height. The standard height lifts I can’t stand straight up under a truck. I think they need a little over 13’.
leadfarmer
Hot Rod !!!
2:26 AM
S Central PA
Cathedral trusses over the lift
Fresch
2:26 AM
Cny
Better hurry you could have 10' of snow by morning! ;)
Dustin4185
2:26 AM
East TN
I’m in the south and did a turndown slab, two courses of 6” block, then 8’ studs. Not nearly enough room for a lift, but it is going in the pole barn. I wish I would have went 28x48 instead of 24x40. I dried mine in one year and did insulation/interior sheating the next. It doesn’t get too cold here, so that worked for us. Stick building walls and getting them up on 2 courses can be a pain!
Blackgreyhounds
2:26 AM
S. Central PA
Basically, I've got nothing to add. I'm no expert. FWIW, we got a 32 x 24 pole barn with poured conctetw floor when we bought our house. It has been a godsend. I know this may be moot, but try to your explsin to your wife that steel roof and siding is far superior and cheaper than asphalt shingles a wooden siding. We are super happy with ours.
chipper1
2:26 AM
Grand Rapids Mi
Key point when building a barn, they only come in one size, too small :confused:.
I cleaned a spot for a 32x48 with 12' lids and a couple 12' lean to's, pretty sure it will be full quick. On the plus side, I may have some space in the basement, the wood shed, and the shed :aplastao:.
J.Walker
2:26 AM
Bristol, NY
Be sure to apply for your building permit before you get to far along in planning.
My building permit took almost eight weeks to get. Now that November is here I'm putting up a 24x48' polebarn with 12' walls.
chipper1
2:26 AM
Grand Rapids Mi
Where's the pictures Jack.
