- 6:01 AM
- Feb 5, 2016
- Here & Now
Guess if I don’t like this stuff I’ll have to do some turkey frying.
Not long. Maybe 6-8 weeks tops. If it’s a low use saw I’ll dump the tank and run a bit of something petroleum through before shelving. I like atf because of the detergents. Gotta run it out of fuel anyway. In the winter up here it’s sometimes necessary to bump the amount of additives to raise the temperature related cloud point of the canola. I’ll have to defer to @00wyk in this department sounds like he’s left his saws much longer with canola in the tank.
To me this is like with most things in life. You do what’s best for you and what your comfortable with. For me it’s worth it to not be breathing atomized petrochemical bar oil of unidentified origin. Could care less about cost. Bar oil is the least of my operating expense worries.
Here's one : best oil for high heat?
Most likely the thickest. Just use some 80/90 in there. It will thin down…. eventually & smell like chit too. It will make cutting a really enjoyable experience…Here's one : best oil for high heat?
Use ur 9 gallons and after that switch to a natural based oil. Do some thing for the environmentUnfortunately, after a doing a google search for Canola and Rapeseed oils, I can still buy my petroleum based bar oil for the same price ($6-7 per gallon)... Although I would like the positive side affects of using a natural based bar lubricant, it’s actually easier for me to buy the Mystik bar oil and costs me no difference. Plus I already have another 9 or so gallons on hand waiting to be used..
Yes Sir !Just mixed today ?
Rural king, Blair's, Stahl's, and Lowes have cheap bar oil, perhaps still cheap enough with shipping to beat your local $17/galOk, with crap getting more expensive about everywhere, what would be a usable alternative to normal bar oil which is usually just sae30 wt with tack additive. Local bar oil prices have jumped, it's suddenly 17 dollars a gallon, for any brand except harvest king which that went up also to 23 dollars for 2.5 gal but is hard to find, always out of stock.
Times are getting tough, I finished up my commercial thinning job, it just needs some logs hauled off it after breakup. Now it's tree removal for residential folk and firewood for income, and with the competition, it's gonna be real cutthroat this year. To keep my head above water I need to address some of the consumables and find where I can cut cost.
How is the science project working out ???
I'll have a look after work ...........How is the science project working out ???
