- 11:31 PM
- Feb 5, 2016
- Here & Now
Since I've mixxed it, it's gotten down to the lower 20's for a few nights. I'll snatch a picture later today after I get home from work, I've been busy with my girls softball and work.
is for science Steve lolI just had a 465 rancher kick my rear last week. The oil screen and feed tube was all gummed up from whatever oil they were using. I should have pulled it appart 100% the first time. But live and learn.
I'd say if you were going to use a bio oil. It would be wise to dump some mix or diesel in the oil res and give it a good cleaning and a few piss revs before being stored. It was a pita to get everything working again on this 465. Should have just bought a new hose, screen and pump.
Steven
Any trouble if saw sits? I have personally had veggie blends rot in my tank. However I’ve read STarAIGHT canola will notWe use straight canola for 20” bars and shorter. Zero issues with temps over 20, under that it can congeal if any moisture gets in but runs fine after it thaws. No blown up bars or pump issues over the past 3 years. Highly recommend
I tried Canola oil couple years ago. Oiled fine, problem was when I let it set over winter. It gummed up chain and it would not move. Took chain off cleaned rail with wd40 dumped tank refilled clean oil everything worked fine.Any trouble if saw sits? I have personally had veggie blends rot in my tank. However I’ve read STarAIGHT canola will not
I’ve kinda used up my resources on the used hydraulic oil. Was using new 5 gallon jugs of 303 hydraulic oil. Works great.I tried Canola oil couple years ago. Oiled fine, problem was when I let it set over winter. It gummed up chain and it would not move. Took chain off cleaned rail with wd40 dumped tank refilled clean oil everything worked fine.
My favorite bar oil is used hydraulic oil from log splitter and tractor. No cost used. Different case for new oil going in. Not so cheap.
Don’t know honestly. I run a small outfit year round so nothing is dormant for long. That certainly makes sense though.Any trouble if saw sits? I have personally had veggie blends rot in my tank. However I’ve read STarAIGHT canola will not
+1Canola has a bunch of things going for it: less harm to oneself with breathing in bar oil particles (especially aloft when the powerhead is by your face), less enviro impact where you’re working (especially by water), generally cheaper where we are and it’s never out of stock. We do lots of shoreland work and not uncommon to see oil spray on the water surface, heck of a lot less guilt when it’s easily biodegradable!
Done it in a pinch. I’d try the toilet paper roll trick on it and run it. Just what a mess to deal with cleaning used oilHow many on here run used motor oil? That's the best!![]()
I have used a tank or two of motor oil.How many on here run used motor oil? That's the best!![]()
Clean oil I hope!I have used a tank or two of motor oil.
