Axes and associated items
wap13
5:13 AM
Ga
@wap13 I see it listed anywhere from 4.5 to 8lbs, mostly 6. I bet it’s a 6lb head and 2lb handle. I bet it will work well!
I took it to be different weight/size options. Amazon has a 4.5, 6 and 8lb option, all available with fiberglass or wood handle. At 6lb I would likely still try it but was more interested at 8lb. Guess I will have to order one to get to the bottom of this.....
Thanks SimonHS, I saw it cheaper at amazon also but wasnt sure about posting amazon links here
davidwyby
Rural desert logging
2:13 AM
Extreme Southeast CA
I’d go 6 unless you’re trying to split crazy stuff. That pattern is supposed to work well in lighter heads so 6 should be good.
Moparmyway
Its just a saw
5:13 AM
In a meeting
I’ve got both the 6# and 8# on order. Hickory handles will get a quick sanding and then a couple of coats of BLO
11:13 AM
1.8kg/4lbs "Dragonslayer" head with 40" wooden handle takes the cake 90% of all times.
The other 10% You are better off leaving the wood be or noodle it!
The longer the handle is, the lighter the head can be. The lighter the head is the more often You can swing it without fatigue.
Simple wedge design, 1.8" at its widest, either slices through or bounces off - rarely ever gets stuck.
Without this ax I would not hand split firewood.
I refused a hydraulic/electric splitter as a gift due to this ax!
All my efforts to find a comparable ax head have failed so far.
wap13
5:13 AM
Ga
Let us know what you think when they show up. I'm inclined to go with the 8lb as I have several in the 6lb range and only 1 8lber (fiskars) in the lineup. I hate fiberglass handles so would be nice to have a wood handled 8lb maul
11:13 AM
For me the fiberglass handles on my ax & ax/maul hybrid flex too much cushioning the blow.
Also, their handles are only 32".
I don't use them at all!
wap13
5:13 AM
Ga
I do use a fiskars x(whatever the long handle 4.5lb is) a lot but other than that and my 8lb fiskars all my mauls/splitting axes are wood handled. Thing about the fiskars is I can leave in the bed of my truck year round and the handle dont care
11:13 AM
Yeah, I pay attention to keep my ax handle dry.
I did coat it in engine oil, but still - a dry wooden handle is a firm fitting handle.
I rarely split wood outside of my yard so keeping my ax handle dry is not an issue.
I loaded these into the tractor crate as pictured, my body hates me for it!
Too gnarly to split anyway, gonna noodle them!
SimonHS
10:13 AM
Yorkshire, England
View attachment 399833 View attachment 399834
How about a Helko Vario 2000 Heavy Log Splitter? The head weight is 2.3kg.
Screenshot_20231208-191611_kindlephoto-65613547.pngScreenshot_20231208-191653_kindlephoto-65655265.pngScreenshot_20231208-191722_kindlephoto-65684526.png
This is mine on the right. It could do with a new handle (it has a small split) or at least some care and boiled linseed oil. But the handles always seem to be out of stock. I bring it out for rounds that are hard to split.
11:13 AM
View attachment 399897View attachment 399898View attachment 399899
Make Your own handle!
I do not like the short looking blade and the concave cheeks.
Also, with that many individual pieces I'd be questioning how it'll all stay assembled.
That handle looks kinda short!
What length is it?
SimonHS
10:13 AM
Yorkshire, England
What length is it?
70cm / 27.5"
They do a 90cm / 35.5" handle for it.
davidwyby
2:13 AM
Yeah I after looking I think it’s too close to my oxhead to bother. Whew.
