Another chainsaw dyno...
Red97
5:54 AM
MI
So
Is the DYNO averaging out the runs of same saws? Or is it that some are just stronger than others???
That was an entirely different saw.
When I open the program, it has the last run up. So the new run will save under the old name unless I change it.
That was what happened their. Diff saw same name.
TreeLife
I'm Dominick
5:54 AM
Berkshire County, Massachusetts
LMFAO. You're so serious Dominick. Relax bud. It's all good...
Of course they don't fall out any more. They're using Stihl screws now...
I'm as serious as a rubber chicken or a whoopee cushion these days lol someone has to give you some crap back sometimes.
Red97
5:54 AM
MI
Nice job on the 661, really gained a lot more torque than stock. 395 won’t turn up in rpm for you?
Stock coil.
For some reason I swear they are limited...
Hmmm....
5:54 AM
Stock coil.
Hmmm....
No limited coil on them. It should be able to lean it out sky high past 4 stroke. The carb has limiters on the screws though... you deleted those I’m sure though. How far out on the screws are you from seated?
Nutball
4:54 AM
Mt. Juliet, TN
I ran mine out of gas today to prep for porting (I don't like gas fumes or the chance of a line spraying everywhere as I try to stopper it). It revved way high as it ran out of gas, I let off the throttle because it sounded like there was no limiter.
Red97
5:54 AM
MI
I guess I'll have to try again. Ran a bunch of mtron before it, must have just over looked trying to get more rpm out of it.
SpaceBus
5:54 AM
Downeast Maine
You guys are really making me regret the 395 altogether! The day I was paying for my tractor I saw the brand new 395xp on the counter, and I asked about it and they gave me a discount since it had been kicking around so long. I felt like $999 out the door was pretty good since it came with a 28" bar and chain, I planned on using it for milling since day one.
jacob j.
Only the weird
2:54 AM
Coastal Oregon
I would get your 395 ported and call it good. They're a great saw and much stouter in construction than many others, including the 661. I rebuilt a 661 last year and I was quite
disappointed in how flimsy they are. They run good but the crankcase is very thin and light - several timber faller buddies have already broken crankcases on their 661s.
If you get the opportunity later to pickup a good condition 084 or 088, those are also excellent milling saws - the 084 crank seems to hold up better than the 088/MS-880 crank though.
