Another chainsaw dyno...
wcorey
9:16 AM
ma usa
Well I think the dolly broke it again....
Going to call in the am and see if they have any warranty on the arm I just replaced.
Just some speculation here...
I believe you said the unit is rated for 30hp and a bunch of rpm... but...
Is there a spec for max torque?
I'd guess it doesn't care as much about hp as it does about torque.
When the input is geared 2-1, the torque applied to the arm is doubled.
I think the typical application for the land & sea unit is running directly off the crank.
Not sure how abruptly you can slow a saw down with the valve setup but I know on the disc brake dyno it was possible to get really large spikes in torque if the brake was a bit overly applied, like 4-5 times the saws rated output.
Then again maybe it's just seeing some bad vibe/harmonics, that sort of thing is really difficult to ferret out.
