346 porting (first time)
paragonbuilder
7:17 PM
Norwich, CT
Hard to tell from the pictures, are you using solid solder instead of rosin core? That would make it harder to squish.
I'm not sure. But good chance it's solid. I need to get some different sizes or find some plastiguage.
Tor R
Novice, Leg model #2
1:17 AM
Mandal
i bought plastigauge through ebay, but I would think they are avaible on amazon.
I am almost empty so I need to get some also
I also want to go in an eletrican shop and see if they have thin tin, just for testing
7:17 PM
If you're using the small tube of coiled up electrical solder, it's rosin core. Should be .037 or .039". Can't remember off hand. I roll the flywheel back and forth maybe 10 times til I can't feel it hit the squish band
7:17 PM
The plastigauge is relatively pricy stuff. The one I bought crumbles easily. It may be very old.
You can buy .023 solder on Amazon too.
Dan, you gotta sand out that band or make a gasket with some shim material. I have brass shim material I bought off of eBay and would be glad to mail you a piece. Just triple check all of your squish measurements.
I think I have .001-.015 here. I'd just need the max width and length of the piece you'd need, and the thickness you'd like.
A beer can is usually .0035
7:17 PM
I bought the yellow from oreilly. It will read down to .010" or real close from their website. It's around .035" thick new. It was about $2 a stick or so when I bought the last bunch.
paragonbuilder
7:17 PM
Norwich, CT
I think I'm going to try to sand the squish. It will help raise compression a bit. If Mike is right and I'm closer to .010 I've got a bit to take out with sand paper. But that's ok. It's good experience!
Tor R
1:17 AM
Mandal
almost empty of plastigauge, figured out I should try something else.
50 m 0,6mm
paragonbuilder
7:17 PM
Norwich, CT
Just picked this up. I should be good now.
beaglebriar
The Peanut Gallery
7:17 PM
Warren Center, PA
I think ideally you would want rosin core because it is softer but that might fine. The diameter is good.
paragonbuilder
7:17 PM
Norwich, CT
So I used 3m spray glue and 80 grit sandpaper on the aftermarket prison I had.
I just used a pair of pliers to hold and spin it.
It really didn't take that long. Only took 3 or 4 pieces.
Close enough for me. Do I need to sand smoother with lower grit? Or does it matter?
Tor R
1:17 AM
Mandal
I think I need to try the David Yound metode and this one on 254 :)
