036 build/port
jmssaws
Banneded
12:40 PM
036 was almost 15k and still a touch fat
I'm gonna run it some more in a little bit and try to get it freed up and broke in.
I was running it before the video with the screen in the muffler but removed it to see if it gained,it's noticeably stronger with the screen in.
It doesn't have a screen in the video but will have the next one
cgraham1
10:40 AM
Nor Cal
Good, because I really need to run a spark screen where I cut wood.
junkman
Crush it
10:40 AM
pacific northwest
If i remember right the 034 exhaust flange was a little further back than my 036 was ,did the 034 muffler get used ? or a spacer needed ?I liked the 034 super i used to have ,it was my only saw for years ,the factory opening was a big rectangle in the front cover .
cgraham1
10:40 AM
Nor Cal
The saw is an 036. But it's an 034 super jug
jmssaws
Banneded
12:40 PM
I really like how it runs,cuts wood like a much bigger saw.
It's not far away from the 9pin 7900 in that situation.
junkman
Crush it
10:40 AM
pacific northwest
I don't think so but maybe.
I would switch the drum so I could use the big spline sprocket
With a 28 inch bar on my old 034 and 036 pro the needles would fall out of the smaller bearing once in a while ,after the big bearing and drum upgrade it held up fine .
5000+
1:40 PM
pa
How big is the outlet? I've put the screen back on one or two that had been opened too much.
