1986 Trx250r build thread
Bigmac
10:17 AM
Got my low end together, I bolted on the cylinder with the .190 spacer plate for mock up, and with the gaskets and the pistons was in the hole...so I remove the gaskets and rechecked everything... .190 spacer no gaskets the squish was .030 with 191ex and 126 transfers, so I am going to have to cut the spacer and dome, I would like 191 to be the max exhaust and would like to be no less than 188°, and a little more squish, like .038, I like a tight narrow band. So I think .020 out of the dome and .034 off the plate, gaskets I have are .011, if I cut too much off the plate it’s pretty easy to make up with gaskets, lots of thickness options. The transfers will need lifted and lowered to match the number I want and base of stroke 1531B28D-F76F-4231-81D4-E4608A967256.jpeg5B9B3980-4CB0-49EB-BC06-1C367A74E3B3.jpeg
Steve
Excellence!
12:17 PM
Got my low end together, I bolted on the cylinder with the .190 spacer plate for mock up, and with the gaskets and the pistons was in the hole...so I remove the gaskets and rechecked everything... .190 spacer no gaskets the squish was .030 with 191ex and 126 transfers, so I am going to have to cut the spacer and dome, I would like 191 to be the max exhaust and would like to be no less than 188°, and a little more squish, like .038, I like a tight narrow band. So I think .020 out of the dome and .034 off the plate, gaskets I have are .011, if I cut too much off the plate it’s pretty easy to make up with gaskets, lots of thickness options. The transfers will need lifted and lowered to match the number I want and base of stroke View attachment 173145View attachment 173144
Looking good! I spent alot of time playing with shims on my 8.8 to get the mesh right. Amazing how many options there are!
Bigmac
10:17 AM
Got my spacer and dome back from the machinest
Ended up with 190° exhaust and .039 squish, with a little thicker gasket that I planed, need to lift the transfers.020 to get 127-128, super happy!
I still need to do some clean up work, but now I have a plan! This is before...real time...so it going to be a bit!!
FE124A1D-E0DE-497A-A4D0-126E7BA0BE8F.jpeg E2F2968A-F924-4A7F-AEBE-0474B382BA1F.jpeg
Bigmac
10:17 AM
Got the port numbers I wanted and can now start buttoning the motor up! I need to order up a new intake manifold, I like the short cr manifold, debating on a reed spacer to get a little more room for the vforce 3’s to work there magic, the upper reed petal is close to the intake roof.
Bigmac
10:17 AM
Got to do something while it raining!
Did you decide against the reed spacer or are you like me? Get too excited and have to hear it run!:D
It’s been a while since I ordered a cr intake manifold from Honda, and guess what it’s discontinued! So I decide to throw on an 01 cr intake and reed set up for now, I have to cut off part of the intake flange to install the V force reeds, but this 01 set up is a pretty good set up, and I don’t want to just cut it up, so I will be on the lookout for a good used intake manifold to cut up, and I think I will use to reed spacers for it, since the 01 reeds are not dual like the -forces I don’t need a spacer on it. It will give me something to test down the road!
Bigmac
10:17 AM
97148234-4068-4960-88F0-85C86ED66B24.jpeg E51A6737-21E4-41B0-944B-A5B40EC536CF.jpeg 943DF33F-9836-44CF-A927-7E5155E585C0.jpeg 0948D3BA-17B5-4FD0-AC05-2D365524472A.jpeg
Made some decent progress. Tested the ignition and it works great did a quick alignment on the front end, (a friend was borrowing my angle finder and I got that back today) and I buffed up the pipe, it was looking nasty! Lol should be able to fire her off tomorrow! Waiting for some paint to dry on some things.
