Got my low end together, I bolted on the cylinder with the .190 spacer plate for mock up, and with the gaskets and the pistons was in the hole...so I remove the gaskets and rechecked everything... .190 spacer no gaskets the squish was .030 with 191ex and 126 transfers, so I am going to have to cut the spacer and dome, I would like 191 to be the max exhaust and would like to be no less than 188°, and a little more squish, like .038, I like a tight narrow band. So I think .020 out of the dome and .034 off the plate, gaskets I have are .011, if I cut too much off the plate it’s pretty easy to make up with gaskets, lots of thickness options. The transfers will need lifted and lowered to match the number I want and base of stroke View attachment 173145View attachment 173144
Ya setting up the cylinder is really similar! Getting butterzone! LolLooking good! I spent alot of time playing with shims on my 8.8 to get the mesh right. Amazing how many options there are!
Got some time today, it’s raining like cats and dogs here! View attachment 175243View attachment 175244
Looks great getting close to smoke time.Got some time today, it’s raining like cats and dogs here! View attachment 175243View attachment 175244
Almost McCulloch time lmao.Yes it’s getting closer!!
Ready to drop in!
It’s been a while since I ordered a cr intake manifold from Honda, and guess what it’s discontinued! So I decide to throw on an 01 cr intake and reed set up for now, I have to cut off part of the intake flange to install the V force reeds, but this 01 set up is a pretty good set up, and I don’t want to just cut it up, so I will be on the lookout for a good used intake manifold to cut up, and I think I will use to reed spacers for it, since the 01 reeds are not dual like the -forces I don’t need a spacer on it. It will give me something to test down the road!Got to do something while it raining!
Did you decide against the reed spacer or are you like me? Get too excited and have to hear it run!
