X-cut chain
1:32 PM
So on the subject of chains and without starting a new thread,I’ve been getting a lot of chain stretch lately with both Oregon and stihl chisel chains on my bigger saws. To the point where I run out of adjustment. Have you guys been seeing this too?
Too aggressive chain, or dull chain and utilization of the saws spikes!
In both cases the cutting resistance is too high and a powerful PH will "stretch" the chain pulling it through the cut.
Throw the stretched out chains into the scrap bin, they will no longer merge smoothly with the drive sprocket.
BlacknTan
7:32 AM
New York
It's either a softer, easier to file edge that dulls quicker, or a harder edge that lasts, and a bit more antsy to file.
What I'm waiting for is an alloy tough that can consure bolts and nails, and that files like quarter hard brass... one of these days...
Gullet
6:32 AM
Arkansas
PS:
IF they were made from PREMIUM STEEL, they would be cost prohibitive...
Over $100 a loop?
You could prolly heat treat a chain loop as hard as a file, but it wouldn't last very long.
Skeans1
4:32 AM
Oregon
Schaffer. And I don’t want to hear anything bad about it because I just bought 2, 55 gallon barrels of the stuff! :confused:
Never ran it, how much of the burn wood are you guys still cutting?
Nutball
6:32 AM
Mt. Juliet, TN
I've noticed a couple guys I work with hitting the brake right after each cut, stretches the chain in no time till it is sagging off the bar, but they keep right on doing it.
As for the teeth hardness, I haven't paid too close attention to what brands I'm filing, but I feel like some of the new Husqy chains are super soft to where you can fix a rocked chain in 2-3 swipes, but I did run into a hard Husqy chain recently that took 30min to file (20" chain). I was filing each tooth about 20 times, and the file didn't seem to be biting well. Next chain took 5min & was much softer. That file didn't last much longer, but did sharpen several chains a few times, so I got my money's worth out of that Oregon file.
Gullet
6:32 AM
Arkansas
Oregon files don't impress me.
I like the Stihls A LOT better.
Files in general are not the last word in chain performance.
RPMs & bar come into play.
If you EVER ran across a chain that is anywhere NEAR as hard as a file, it wouldn't last 2 minutes in the cut
Nutball
6:32 AM
Mt. Juliet, TN
What I wonder about is what stays sharp the longest: hard chain, soft chain, or surface hardened by a grinder? Would the soft steel wear away faster allowing somewhat of a self sharpening characteristic as more fresh chrome top plate can be exposed, or would the grinder hardened chain resist edge wear?
Gullet
6:32 AM
Arkansas
What stays sharpest is what your oiler can supply versus bar length.
Gullet
6:32 AM
Arkansas
Even the SHARPEST CHAIN is not the most desirable.
Sharp is one thing.
Sharp longeviy is another
If you have the coin to
Some of it would depend on what you are cutting. Carbide chain makes sense in some situations, but not all.
Philbert
YEAH!
If ya got the coin!
chiselbit
4:32 AM
Norcal
I heard the other day we are done with about one third of the sale. No end in sight. I’ve been using the Schaffer’s for about a year and it seems to be no better or worse than husky or stihl bar oil. Seems to stick to the chain good. Unlike some of the cheap stuff
Philbert
Chainsaw Enthusiast
6:32 AM
East Dakota
YEAH!
If ya got the coin!
I’m not saying that carbide is ‘the best’;
I’m saying that ‘the best’ may depend on the type of wood that you are cutting.
Philbert
