- 3:32 PM
- Jan 12, 2016
- Iowa City
Think I can take 6g of mass off this meteor piston safely?
Yup, but you can take 6g off the stocker safely too.
Hey Shaun!Yup, but you can take 6g off the stocker safely too.
Do any of you guys think you could use a tapered reamer to lighten the pins?
Or would they be to hard?
The balance of what? The whole rotating assembly?I was told to absolutely NOT to try this, as it would ruin the balance from not being absolutely perfect. Would cause more harm, than it did good.
The Piston left and rightThe balance of what? The whole rotating assembly?
The oem ones are tapered and the AF ones are straight.
I have to believe anything that's lighter on the small end of the rod will help. It's all reciprocating weight not rotating weight.Balance... who was it that made a full circle crank.... No balance there.
These factors are all real but I wonder if the order of magnitude is great enough to warrant consideration.
On the flip side I have heard lightened slugs cause a saw to spin up much quicker...
Sent from my SM-G955U using Tapatalk
If the measurements of the ID is the same after reaming them. I'm guessing it would be very close to the same from side to side.The Piston left and right
If it was machined the same on each side...I was told to absolutely NOT to try this, as it would ruin the balance from not being absolutely perfect. Would cause more harm, than it did good.
has anyone checked a pin for hardness? Are they just case hardened and soft inside or hard tool steel throughout? Reamer will probably *s-word the bed trying to cut something 50-60 rockwell. It's essentially a bearing race after all.
Would t it just have been easier to buy the right part?Now,hard steel .I cut the shaft down from a Ford water pump bearing to repair a Chevy 292 in line 6 .Being powdered metal it was so hard C2 carbide inserts would not cut it .It took ceramic .
Keep in mind you have to chuck up the pin to bore it out without harming the finish of the pin .With hard steel that isn't all that easy to do .All that forkin around if you really wanted a lighter pin use the OEM pin to begin with IMO .
This remind me of turning an 038 AV into a mag when it's a lot easier to just start out with a mag to begin with which in reality they made more of than the AV's. Different strokes for different folks though .
