- 5:15 PM
- Jan 12, 2016
- Iowa City
This has my interest.
I ordered one to try as well.
How long’s your delivery time?I ordered one to try as well.
You fellas try to break em, and report back. I wonder if CC Specialty collets fit.
You'd be the real koolaid acid test for longevity, prolly put more use to it in a week than most of would do in a year.
Pics of the collet are sort of blurry but looks sort of shorter/fatter in proportion.
I like the layout they use to tighten them though, the cc's are kinda marginal there...
Once I hear that these are indeed small enough to actually work in a saw jug, I'll order a couple.
That’s good. You might have it before I do. What was the dollar cost? It was £61 to me delivered. Just wondered if it’s cheaper to you or around the same.Estimated Aug 19th when I placed the order, I'm sure it will get here sooner. DHL only takes a few days to get here from China.
I’ll try my best. Maybe I should’ve ordered a couple. Ha.You fellas try to break em, and report back. I wonder if CC Specialty collets fit.
I’m hoping they’re decent measurements. Might be tight. Will need to cut the shank on the burs I think.They show a length of 22mm for the head, cc 182 is around 20 and change, so reasonably close...
Is that a dentist drill?I've been working on a option for small cylinder and lighter duty work. I'm trying to finalize the burr selection I will provide for them.
I thought that. It made my teeth hurt when I looked at it.Yes, it's a dental head.
it looks nice and small. Is this something you will be selling?
cool. well let me know once you're ready. i'd be interested in one.That was my plan. I can make the adapters, heads are cheap and I can supply a few modified burrs that will fit them. The head is about 1/2 the size of the CC182MC so you can grind the entrance angles you want in small bore cylinders easy.
