- 8:30 AM
- Jan 24, 2018
- Extreme Southeast CA
@kkempI have a good used 288xp Mahle jug with decomp sitting on the shelf…
The top decomp models don’t have the oversized holes like the side decomps doSo, why did Husqy go the way of Stihl by putting their decomp buttons on top? I liked them on the side. No risk of it dropping in, and the hole gets covered near the top of the stroke, so you get a little compression pop, which in my opinion makes starting a lot easier. I don't like the blow/suck feel of the top decomp engines. Maybe that's just due to oversized holes in the valve.
Does porting help the 500i or 400?
Or is it worth it?
It depends on the designs. Most newer saws gain less than older models. The manufacturers figured out a lot of stuff over the years.
When a saw gets ported, we are just trading certain traits away for others. We sacrifice noise, fuel economy, emissions, and/or reliability for more power. If anyone thinks they can beat the Billion dollar OEM manufacturers at their own game from their basement they are certainly fools.
I’ve only done one 620 and the guy is pretty happy with it. I found it needed better air filtration and a gutted muffler with a larger factory opening to not be held back. Ran pretty well and had a good low end for a saw of it’s size.
really? where was the first engine made?
where did the light bulb come from?
the billion-dollar oem manufactures have only improved what someone did in their little shops.
who do you think comes up with these idea's?
the strato engine was thought up by a guy in his little shop, made a blueprint of his idea and patented it. the oem's bought the rights to use it.
Basement dwellers do not have some of the limitations the mfrs do. Obv…the porters are turning out new saws that run better than they did from the factory.“If anyone thinks they can beat the Billion dollar OEM manufacturers at their own game from their basement they are certainly fools.”
I’m with Doc on this one...
Apples to oranges.really? where was the first engine made?
If anyone thinks that there aren’t lookers on here from Stihl or Husqvarna, you’re living under a rock. You don’t even need to be a member to google topics and view it. Of course they have millions of dollars and huge research facilities to test, but what porters do does not go unnoticed.Billion dollar companies buy and/or steal ideas from people. They'll hire people to figure stuff out when they have to, but they'd rather take the easy way. They have money and can capitalize on new ideas. Tree Monkey is right.
And that’s exactly what I meant by that post. I’m all for it though - if they can learn something here, let ‘em! Now in a perfect world, they would contact their favorite porter, and pay for some royalties or offer them a job. But let’s be real: they are going to gain what they can for free, and continue to make their stuff better and continue to make more money..There was fella from Germany(Stihl) on here, he posted a pic of his bench. He used to follow the porting threads right along, then he disappeared and a while after that the 462 was introduced(Factory Hot Rod).
I don't think you need much more of a crumb trail to put two and two together and come up with four here.
First thing I said when I first laid eyes on the insides of a cylinder, "they been cheating on us".
Being fairly impressed I saved a copy of his workbench pic.
that's a really clean and well organized work benchThere was fella from Germany(Stihl) on here, he posted a pic of his bench. He used to follow the porting threads right along, then he disappeared and a while after that the 462 was introduced(Factory Hot Rod).
