- 10:17 AM
- Jan 17, 2016
- Wv
stihl ultra?
stihl ultra?
It was a ag bike not a high stress mx engine. Was over 20 years ago but I actually think the degreaser had some lub to it as there would have been no oil left in the engine after a few min.Crikey, DEGREASER as a lubricant! Yeah, that's just plain weird, I wonder if the inside of the engine looked a lot cleaner. At least something like ATF has friction inhibitors in it. There's enough detergents in ATF that it was a common practice to put a quart of ATF in an engine's crankcase to try and free up sticky lifters (it often worked), but I doubt it would free up sticky rings in a two-stroke.
4T oil long term might carbon up a saw but who knows with all the high-tech 4T oil out there now days it's nothing like the 4T oil they run in saw's years ago.I want to see a test where Automatic Transmission Fluid (ATF) is used, also some 10-40 weight 4-stoke oil. I expect both would smoke more than a FD oil, but how about deposits and wear of the engine? I know both will lubricate a low output engine like a chainsaw and keep it from seizing, but what is the long term effects? Anybody game to give it a go?
Come on, does somebody have a crappy saw they are willing to dedicate to the test? Just mix up some ATF at their favorite ratio, fill the tank and flog the bugger.
Ill be doing some oil testing on a new string trimmer. Ill load up the spool, bump out till correct length. Do my normal heat cycle break in I've used since my days of 1/5 th scale rc racing, then it going to be clamped to a steel saw horse outside and ran wfo tank after tank on 90 e free and what ever oili start this "test" on.
Well.....im going to use the oil I've been using for over 15 years first. It wasn't until these threads that I found out how "stupid" that was. Anyway, Blue Marble. Used it in all my 1/5 th scale race cars and ope since a fellow racer and hobby shop owner turned me into it. I have experienced personally the claims they make. Its a "universal" oil and isn't even synthetic. But its always worked so I never looked elsewhere till last few months.
It is indeed the lucky man that finds an oil that just "works" and calls it a day in the great "Oil Wars" and is content
AMSOIL Saber at 40:1!!!
Im with you to a point. All my ope and even the rc race cars. They run like they should, no reason for a tear down. I will however have no issue blowing up a cheap weed eater or leaf blower. Or tearing it down for the good of the oil worshipping flock.Only reason im using a new one first go round is to see what that crappy, snake/ boat/ snowmobile/ universal oil I've been using really does to an engine from new. After that is onto saber at consistently leaner ratios until something goes.
I believe years of use and experience trumps a paper or label that says A won't work in B. Not advocating running boat oil in ope but im sorta doing it and apparently a well know saw porter runs "boat oil". Some previous post over this thread stated you can't judge an oil till you use it for years. Except if they don't agree, then 20 years means nothing. I use what works for me, not a blind fan boy of anything. If I find a better product, at least in my mind anyway, I'll switch.
Just to see my friend. Just to see. Not only is saber supposed to be guaranteed to 100, supposedly it was tested in texas at some lab at 300:1 and passed but Amsoil knew 100:1 was going to be hard enough to get people to buy into. In my quality ope, its 3.5 oz to gallon no matter what my little test comes up with. For fun if you will.
In my experience, proper tune, clean air filters, sharp chains, and oil ratio matter more than brand or type of oil.
Almost forgot an important correction for the belief that dominator doesn't have rust inhibitor. I actually called the Amsoil technical department last week. I brought this up. He said Dominator oil has a full additive package which includes rust and corrosion inhibitors. He was honest, imo, because he also admitted..."not as much as some other oils". I asked "then whats the deal on the astrix about boat motors"? He said because engines designed for TW-3 oil can get ash deposits from running an oil designed for high heat applications. Frequent tear downs are recommended to inspect for build up and removal of said deposits. Nothing to do with rust. Maxima K2. Called them. They said absolutely there is corrosion and rust inhibitors in that oil as well. People need to keep in mind. Environment and using e10 gas greatly increase the chance of internal rust. Another point people loose track of. Fogging oils were around long b4 ester oils were in wide use. There is a reason. Some old school loggers in northern states would drain their gas, run carb dry and then pull the plug and fill the engine to the top with 30w motor oil. In the spring they would dump it out, rinse it with fresh mix and run it. Smoked like a crop duster to begin with. But, no rust in storage. My point is, no oil is a guarantee of a rust fee engine interior, nor is any type or brand of oil a guarantee you "will get rust". There is a reason the old loggers did that. Im guessing someone had a rusty bottom end way back then and took action. And like most things, it spread. Myself, I just start my stuff every couple weeks. I like to hear them run anyway.
I used to fog my dirt bikes. When i went to a tech school for diesel and auto mechanics in the late 80's they were telling us about this study. Don't remember what institution conducted it, but it was to see the effect of an engine setting unran and the resulting damage. It focused mainly on the bores. They were able to calculate how many hours, on average, you decrease the life of an engine from setting. 30 days was something like 40 hours if I recall it correctly. Been a long time. That number could be less or more. Don't beat me up if im to far off and someone finds that study. Not only was there rust forming at times but just being dry on start up causes excessive wear. The results prompted me to fog or run every couple weeks. Back then it was fogging. Of course a chrome or nickle bores in most ope and bikes really probably wont have those issues but rust in the bottom can happen.
I've used seafoam. Not the creep stuff. The add to the gas stuff. That "snake oil" seemed to take care of a surging issue my gx335 deere garden tractor had. Saved me doing a carb teardown. Could be a kwinky dink or it works. Project farm seems to think so.
I spray it into the carb throat on my Evinrude 25HP while under power. About kills all the fish near it!Your degreaser accident sounds a bit like the process of sucking a bottle of Seafoam in through a vacuum line and running at high idle
Smoke galore and supposedly washing out all the bad stuff from the carb/injectors through to the exhaust
My son has done it multiple times on multiple vehicles and never seized one up or shortened the life
I am not that brave and just put a splash in my premix and a bottle in my Toyota's gas tank a few times a year
