Billy Currie
12:36 AM
Asheboro, NC
I think someone here has ran FHS 62R oil as premix. I've just started running it, finished up my first gallon of mixed fuel at 40:1. It seems to run ok, milling with it. Any input on it?
Just wondering if I need to start shopping for a new cylinder and piston. :biggrin:
I hear that :chuck: uses it in his equipment.
Terry Syd
2:36 PM
Comboyne, NSW Australia
I want to see a test where Automatic Transmission Fluid (ATF) is used, also some 10-40 weight 4-stoke oil. I expect both would smoke more than a FD oil, but how about deposits and wear of the engine? I know both will lubricate a low output engine like a chainsaw and keep it from seizing, but what is the long term effects? Anybody game to give it a go?
Come on, does somebody have a crappy saw they are willing to dedicate to the test? Just mix up some ATF at their favorite ratio, fill the tank and flog the bugger.
CR888
2:36 PM
I've been wanting to do just this, been discussing it with another member. I need a semi decent China sacrificial saw, but something I'd be happy to use enough to get the data. I think a bauma-Ag 40/50/60cc is the ticket. The new returns get sold off on eBay with a starting bid of $0 & can be had a lot cheaper than buying NIB. Warehouse is in Seven Hills NSW wherever that is. I bet a test like this would be an eye opener to many. I have some Makita top handles that owe me little but there clamshells & I'd want a nice easy to remove cylinder like the Husky 372 clone.
00wyk
5:36 AM
Ireland
Ahh, the internet. Always asking questions it already knows the answers to.
CR888
2:36 PM
So you discussed oil with the M/Mind....he suggested you take a look at the oil thread & now your more confused with more questions than had initially :eyepop: :nut: :nusenuse:... That's all good we're all pretty nuts here, welcome to the forum. Let us know how good your saw taste is, what saw you gettin porded?
CR888
2:36 PM
lol true! By semi decent I mean not a eager beaver, mini Mac. But something I could use enough to get the data without making me wish I didn't come up with this stupid idea. I don't have a good macro camera either. It would be good to test 30w, 15-40 multi viscosity, ATF, a veg oil like olive or canola, a full syntyetic 4T and the last test could be a dark brown/black well used motor oil past its service schedule.
rogue60
2:36 PM
AU
I've run a few tanks of fuel through a 066 using used diesel oil as mix oil but nothing bad to report saw was fine.
But I've got better! I picked up the wrong tin and put degreaser in a 2T bike rode it around for a good half hr thinking something is odd with amount of smoke it was blowing lol
When I worked out what I'd done I just drained the tank and put the correct fuel mix in it I got years more out of that bike it never did blow up or anything.
Oil is over rated..lol
Terry Syd
2:36 PM
Crikey, DEGREASER as a lubricant! Yeah, that's just plain weird, I wonder if the inside of the engine looked a lot cleaner. At least something like ATF has friction inhibitors in it. There's enough detergents in ATF that it was a common practice to put a quart of ATF in an engine's crankcase to try and free up sticky lifters (it often worked), but I doubt it would free up sticky rings in a two-stroke.
3browns
8:36 PM
Fishhook, Alaska
Your degreaser accident sounds a bit like the process of sucking a bottle of Seafoam in through a vacuum line and running at high idle
Smoke galore and supposedly washing out all the bad stuff from the carb/injectors through to the exhaust
My son has done it multiple times on multiple vehicles and never seized one up or shortened the life
I am not that brave and just put a splash in my premix and a bottle in my Toyota's gas tank a few times a year
