2:00 AM
You guys wanna put some money on them Wackers?
I got a fs250 that takes no prisoners
Mines a little 33cc if I remember right. What's the 250?
jake wells
no longer here
1:00 AM
ky
now we need brad snelling here to tell us how bad ass the oil from baileys is.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:00 AM
Provencal, Louisiana
A trim off!!!! :cunaooooo:!! A word of warning, if yall run mine I have lowered rakers on my line!! It pulls hard when u hit the grass it may flip u!:buitre::cunaooooo:
Moparmyway
Its just a saw
2:00 AM
In a meeting
I run my R50/800 mixture just to use it up.
I run 24:1 for stumping ......... sometimes I burn my hairs off my hands/wrists ................. so I am cautious about lubing my worked stuff
Here is my mixture @ 24:1 after a gallon or two in my 661. Cant remember what was done to it at this point, but the piston aint flat anymore IMG_1954.JPG
Keith Gandy
1:00 AM
Here is my mixture @ 24:1 after a gallon or two in my 661. Cant remember what was done to it at this point, but the piston aint flat anymore View attachment 18631
Thoso 661s all have a wash pattern like that regardless of oil? Thoso quad ports must have serious velocity?
jmssaws
Banneded
1:00 AM
I like it kev
Moparmyway
Its just a saw
2:00 AM
In a meeting
Honestly, every oil I've tried leaves carbon on the piston tops.
I care more about the ring lands with regards to carbon than the tops of the piston.
Every oil I've ran has lubed and I doubt that any of them would produce any failures
The VP SEF that I run is why the piston shows the wash pattern.
The same mixxed oil in pump gas carbons up terribly with no wash pattern in some of my other 2 cycle stuff ........... including leaving some carbon in the ring lands
Fuel plays a large role in deposits and some oils do leave more deposits than others. Where the deposits are is critical, no matter what oil or what fuel one uses.
Piston top = NOT critical
Ring lands = Critical
jake wells
no longer here
1:00 AM
ky
Fuel plays a large role in deposits and some oils do leave more deposits than others. Where the residue is left is critical, no matter what oil or what fuel one uses.
supertech at 16:1 with 40 octane corn gas is best :cunaooooo:
Keith Gandy
1:00 AM
I believe u on that fuel quality. How do u buy yours ? 5 gal. Pail?
