skidooguy
Genuine smartass
5:20 AM
Wyoming
When I bought my 461 they talked me into buying some ultra for extended warranty supposedly. The only thing ultra about that crap is ultra smelly. I like and enjoy the smell of about any 2cycle oil but I will not be using that stuff for much other than chain oil on my dirtbike.
Ron660
6:20 AM
NW Louisiana
So then what's it's purpose in an oil? Lubricant? Solvent? Anode?
Lubricant what I've been told. A dirt track racer, and mechanic, recommended Valvoline for my 350 engine due to the higher zinc and phosphorus content for additional protection. I've been using 10W-40 with no issues.
Ron660
6:20 AM
NW Louisiana
I've always used valvoline in my vehicles.
That old mechanic said he's used a lot of different oils and Valvoline gave the best protection. He also built dirt track racing engines. A chemical engineer I know told me Rotella 15W-40 showed the best lab results.
concretegrazer
6:20 AM
Mo
Im not sure but here is an interesting article that would pertain to oils full of zinc:
The effectiveness of Zinc in your oil is also affected by the quality of the base oil the manufacturer uses. Besides its protective qualities, Zinc is also an anti-oxidant. Manufacturers of lower-quality motor oil use Zinc to mask the deficiencies of their base oil which will begin oxidizing even under normal engine operation. That leaves the Zinc doing a job besides protecting your cam, which means that, just like the previous example, even though the oil may have a higher concentration it won’t protect your engine as well as a performance oil that actually has less Zinc but uses a higher quality base oil that’s not as susceptible to oxidation.
Anti wear
Reread...light came on.... Makes since now.
7:20 AM
I've seen tests showing Rotella at the the bottom as well. Valvoline and mobil 1 were the top 2 in least iron in the oil after a run cycle. I've not seen good results with Rotella compared to valvoline, mobil, and Castrol enduron S. Castrol was the cleanest in the valvetrain. It had more detergents than the others. They've taken zinc out of a lot of the diesel oils for emissions. The flat tappet cams can use more zinc and John deere 15w40 had the most in it. The 5.9 and 6.7 Cummins are flat tappet cams.
