3:59 AM
Hybrid gettin ready to go back together and all cleaned up of carbon for my ole buddy Ronnie!! :cunaooooo:! Think the next test oil will be 800t @ 42to1 with the current tune for 4 tanks
Any timed cuts with the kl200?
Cut4fun
Redneck Chainsaw Repair
3:59 AM
Ohio
IMO run what you want. But dont try and feed BS to others.
There is a reason I never switched or go back and forth trying different oils like alot of folks.
I found what works early on for me. KL-200 ;)
Keith Gandy
Maxima K2 40:1 87 Pump Gas
2:59 AM
Provencal, Louisiana
I just wondered. I'd like to see the difference in the 800 and klotz in same wood and all.
Ill time 800t this time and tear down and clean and retime with kl200. Hybrid back together with dye black handle but ill have to order 800 for test. Bottom 2 pics r of klotz kl200 @ 42to1 that I forgot to add these pics in my post with cylinder/piston20160410_085440.jpg20160410_085422.jpg 20160410_080042.jpg20160410_080038.jpg
junkman
Crush it
12:59 AM
pacific northwest
Are you liking Dumonde the best so far?
The dunonde is one of my favorites ,if had the 250 r still it would get that oil
As for my weedeater no
Ill time 800t this time and tear down and clean and retime with kl200. Hybrid back together with dye black handle but ill have to order 800 for test. Bottom 2 pics r of klotz kl200 @ 42to1 that I forgot to add these pics in my post with cylinder/pistonView attachment 18480View attachment 18481 View attachment 18482View attachment 18483
Nice 029 ;)
Cut4fun
3:59 AM
Ohio
You need one of those all black non flippy caps for that black tank.
Here is the 2 out.
LCS locking style and CCC non locking style.
http://chainsawrepair.createaforum....s/video-of-the-stihl-flippy-cap-replacements/
http://chainsawrepair.createaforum....ppy-replacements-en-route-from-hong-kong-now/
index.php
index.php
index.php
Keith Gandy
2:59 AM
Ron660
2:59 AM
NW Louisiana
I can't find it. Pretty sure the 800 wasn't the fastest or it wasn't in the test. In my tests it was the slowest by about 8%. Here's the chart with the hp2 being the fastest.
Klotz the slowest? Again, different saws will probably different results.
CR500
3:59 AM
Western NY
different ratios as well.... H1R was faster at a different ratio if I remember right.
Klotz R50 is a pretty thick oil...
Keith Gandy
2:59 AM
I would think a higher viscosity oil at a low ratio would be for protection and not performance? Too much oil will impede combustion resulting in less performance? Plus some oils dont combust as readily as others
jmssaws
Banneded
2:59 AM
Why would anybody run a high viscosity oil at 32:1?
