CR500
6:28 PM
Western NY
Klotz super at 40:1 is still to much oil for firewood cutting.
I run 50:1 now and it's about right,klotz lubes better so the problems people have with it being dirty Is from using way to much oil,32:1 is silly for cutting firewood,no way can it burn all of it.
Certain oils maybe more is better but this isn't one of those oils,50:1 is more than enough with klotz.
Are any of your saws ported?
Sent from my non internal combustion device.
CR500
6:28 PM
Western NY
Everyone,porting is kinda what I do.:)
Sorry lol.
I do kind of wonder if 50:1 is safe with some oils even in ported saws. Klotz is known for lubrication and even at50:1 some have plenty of oil left behind.
Now some oils like 2R which I do like I prefer at 32:1
R50 at 32:1 was not to bad to me but I never thought about decreasing my ratios until a few weeks ago
jmssaws
Banneded
5:28 PM
40:1 is what I recommend for my customers to run but with klotz it's a little to much still. All I see from it is a nice wash and carbon after a couple years use.
stihl saws
You can always justify another saw.
6:28 PM
Virginia
I have a Husky 323L trimmer that I've only ran on Stihl ultra 50:1. It's always left a nasty, dripping mess out the exhaust. I've pulled the cat, retuned and it still doesn't burn clean. The same mix runs clean in my Fs250r trimmers. Any thoughts on this?
jmssaws
Banneded
5:28 PM
A dripping mess can only be from a rich condition.
stihl saws
6:28 PM
Virginia
That was my first thought too. Even after the cat removal and retune I still have an oily mess running out the exhaust. My tuning can't be that bad if this is the only trimmer with a issue.
stihl saws
6:28 PM
Virginia
Are husqvarna trimmer coils rev limited? Never thought about that, but maybe that's my tuning issue. Or?
KenJax Tree
¯\_(ツ)_/¯
6:28 PM
Over there
My 326LS is the same way
stihl saws
6:28 PM
Virginia
I wondered if it was just me or the oil I was using. What do you run in yours? I'm switching everything over slowly to K2. We'll see how that works.
Sorry I've side tracked a good oil thread.
KenJax Tree
¯\_(ツ)_/¯
6:28 PM
Over there
I've used lots of different oil including K2 they all pretty much made a mess. Never a problem in anything else though.
stihl saws
6:28 PM
Virginia
It's been happening way before the cat delete. It will leave blisters on my forearm after running for a extended period of time with a short sleeve shirt. Definitely not lacking for heat.
cdixon
6:28 PM
Western North Carolina
I run my new Stihl at 50:1 on Stihl Ultra. It's great oil and the saw is under warranty. I run the rest of my my saws and leaf blower on Sthil HP at 40:1 and a splash of Sea Foam. Sthil HP is the best conventional oil I've used. Husky weed eater I will be running it on the Stihl Ultra this year. Warranty expired last year. Had been running it exclusively on Husqvarna LS but I didn't like the carbon build up I was seeing. At 50:1. Both Stihl oils burn a lot cleaner. And the Ultra oil apears to have cleaning properties.
