Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 1:14 AM
- Dec 30, 2015
- Provencal, Louisiana
What saw was this Jeremy?Not sure B
Fuel maybe?
Saw was tuned @ approx 13.2-ish
Fuel maybe?
My 660 was tuned to 13600 on 110 and 13750 - 13800 on 93....still very clean internal. And a lot of cut time was noodling red oak and white oak. I'm starting on my 3rd liter of 800 off-road.Not sure B
Fuel maybe?
Sometimes its hard to see carbon through the plug hole especially if its lighter black to grayyish. U may be suprised to see the cylinder pulledMy 660 was tuned to 13600 on 110 and 13750 - 13800 on 93....still very clean internal. And a lot of cut time was noodling red oak and white oak. I'm starting on my 3rd liter of 800 off-road.
when i ran h1r my piston was clean like that from being too rich ,was washing the top of the piston from too rich ,and my muffler cans were wet inside also .they are dry now the way i tune ,the finger ported hybrid tunes higher than reg saws so do not tune off my rpm #s i am posting .Not sure B
Fuel maybe?
only bad thing i can saw is it leaves the muffler a little sooty ,like a woodstove pipe gets ,my plug color is excellent with it ,i need to put my camera inside see how the piston looks still ,as for performance it runs real good on it ,i thought 40 to 1 would make more power ,it made more with 32 to 1 when i mixed a fresh batch yesterday ,plus i like the cool blue colorComments on the Sabre?
Sounds good. I tune my 440 or 460 around 14200 to 14800 depending on wood size but I rarely cut over 28" with either of thoso saws20" or 25"
Cleaned up perfect and pulled like a freight train in the cut.
Rich.....maybe
Excessively?......No
13.2 is only a few hundred below spec.
I dislike a 70+cc saw that screams like a banshee. It's not normal to me.
Besides.....it's not about max RPM unloaded to me that matters. It's how it eats what you feedin it.
I ain't out to win races n *s-word brah.
I wanna cut wood, have fun, and protect my saws the best I can. And I like them to smell good while doin it![]()
Not sure if it says that on the jug or not, but it definitely says meets Jaso fd. The pwc oil is different than boat oil. I'm guessing because of the multitude of rpm's they commonly run at. But after all the fuel that's been run through it, there's no carbon in the exhaust. At all. Oily and shinyIsn't that TCW III?
My 660 and 036 mufflers were a little wet I have to admit.My mufflers are dry
The Benol may not burn as easily. I've never run it.I switched from super technoplate to benol because they was out of super, she gas as always but every saw needed richend up,quite a bit too.
What's the deal? Ideas.
Is benol thicker than super techniplate? If so, combined with colder temps, that would make sense.It was 20 degrees colder then the last time I ran my saws also.
