5:08 AM
I liook at it like….if you use your equipment regularly you shouldn’t need a fuel stabilizer. If you don’t use it often enough that you require a fuel stabilizer, it doesn’t matter what kind of two-stroke oil you use as you’re not going to wear it out. I don’t know, just my thinking.
I choose to use better oils because 95% of the mixed gas I use is burned in customer saws.
mainer_in_ak
1:08 AM
Interior Alaska
Some of the fuel stabilizers supposedly have Polyetheramine. Like marine stabil.
I saw two weird changes in my equipment when using marine stabil in all the fuel:
2 stroke: exauhst ports still had carbon build up, but it wasn't hard, it was the consistency of grainy bubble gum. You could almost scrape the carbon out with yer finger nail.
Once I went to startron stabilizer, the carbon build up in the exauhst port was hard as a rock again.
4 strokes: If I used too much marine stable, I would get a " blue-green stabil booger" that would develop in the fuel filter and the bottom of the carb bowls.
mainer_in_ak
1:08 AM
Interior Alaska
Still using cheap/plain-jane Lucas 2 cycle in all my 2 strokes. Can find it at any O'Reilleys napa or autozone for $9.99 a quart. Year #3 in the saws using lucas.
Funny thing: completely overhauling an 80hp suzuki 550 2 stroke. Oil injection tank full of lucas. Just bout finished out. Compression was a little low at 7000 miles. Ring gaps sloppy, piston skirts deformed and sloppy.
Anyhow, I noticed that the throttle cable is broken! The oil injector pump side if the cable is snapped and wasn't working. I dont know how long this motor has been fed oil metered only for idle, while I full throttle the fker every day.
The bottom end is just fine. No signs of heat not a spec of blue discoloration on the rod ends. So just a routine top-end refresh.
$120 for a freaking throttle cable. As much as a forged piston.
EFSM
4:08 AM
Extreme southern IL
Some equipment (especially trimmers, both hedge and string, and leaf blowers) is used hard but is very much seasonal. The stabilizer in Red Armor does an excellent job with keeping fuel good for up to a year. I recently dumped some RA fuel that was at least 3 years old out of a rarely-used saw of mine. The gas wasn’t fresh by any means but it wasn’t damagingly stale or separated either.
5:08 AM
I don’t have any problems with our ethanol free gas lasting a couple years if it’s sealed. Dominator in the weedwhacker and blower runs in the spring just like it did in the summer and fall. The fuel in the lawnmower and wood splitter doesn’t have any stabilizer in it unless I add my own. I guess I’ve never seen the issue
bwalker
5:08 AM
Montana
Why? Because of how fast you use it? Or because stabilizer is displacing lubrication?
I make sure I use it up pretty fast. If its not used in the saws my son uses it in his lawncare equipment.
Stabilizer can cause increased deposits and it just encourages guys to use nasty fuel. It also doesnt work as well as guys think, especially with ethanol fuel.
If a guy really wants he can add a bit of Stabil. It works as an anti oxidation, but will.not prevent volatility loss.
bwalker
5:08 AM
Montana
One thing about wster oils like Dominator or K2 is one should be aware they are not very good at protecting engines from rust during storage. Its just a property of ester oils.
A little fogging oil cures that.
bwalker
5:08 AM
Montana
Be careful of those Wisecos as it pertains to warm up and skirt to wall clearance. Also looks like the crown profile is going to give you more compression.
bwalker
5:08 AM
Montana
O'Reilly also sells Mystik Sea and Snow, which is a better oil than Lucas and cheaper to boot. It runs $35 a gallon.
This is the same oil as Citgo Sea and Snow. Its FD rated snd I have used dozens of gallons of the stuff in sleds with great results.
EFSM
4:08 AM
Extreme southern IL
Not surprising. I’m talking about the real deal corn juice gas. I have worked on many hundreds of machines with fuel system damage from ethanol fuel that wasn’t yet 3 years old. However, there are more factors that affect fuel life—temperature change, sun exposure, and as you mentioned, how much oxygen can get to it.
Has anyone ever noticed that gas lasts longer in an aluminum fuel tank vs a plastic? Thoughts on why that is?
bwalker
5:08 AM
Montana
Because plastic is actually porous and will alllow some some moisture to enter the can and some volatile compounds to leave.
5:08 AM
That makes sense. E fuel here works ok in a saw for about 4 months. After that it starts detonating or pre-igniting and they don’t turn off immediately with the switch. Something is hot in the combustion chamber and saws will diesel for a few seconds after switching to the OFF position
JRHAWK9
4:08 AM
Lake Delton, WI
Let's see some pics.
Echo 355T Handful of tanks only run on Dominator @32:1
Husky T435, only ran on Dominator. Dozen or so tanks. @32:1
Husky 346XP. Ran on mostly Bel-Ray H1-R and then Honda HP2 over 12+ years. @32:1
Husky 550XP. Ran first on HP2 for a winter and then on Dominator this winter. @32:1
EFSM
4:08 AM
Extreme southern IL
Yeah we had a whole batch of saws come in once from a TSI company. Complaint was that they wouldn’t shut off. The fuel tested at 40-50% ethanol, and once they ran for a few minutes, they would diesel and not shut off.
EFSM
4:08 AM
Extreme southern IL
I figured so. Some of the newer tanks, like the newer injection molded tanks, are supposed to be better (less porous) but we’ll see.
