- 11:26 PM
- Sep 3, 2025
- Illinois
Yeah I should add I run E free 91 octane gas.I don't have issues with Dom about rusting. But I NEVER run my stuff with corn gas.
It has a rust inhibitor package just like the others, but it doesn’t have a fuel stabilizer. That came straight from an email to AmsoilSo something I've wondered for awhile if you Google running Dominator in saws it says it lacks corrosion inhibitors and fuel stabilizers. So is there an issue with that oil stuff sitting in that for a weeks? Months? Years? Sometimes I run saws non stop for a month and sometimes they sit without being touched for 3 or 4 months depending on the saw. Any issue with rust? Or is Google pulling this from something an idiot said on another form?
Eggshooter proved that a few years ago. Put several different oils onto a piece of shiny steel and set them on a shelf for a year in his damp garage. Dominator didn’t rust at all.It has a rust inhibitor package just like the others, but it doesn’t have a fuel stabilizer. That came straight from an email to Amsoil
Ok thanks! I hadn't seen that test.Eggshooter proved that a few years ago. Put several different oils onto a piece of shiny steel and set them on a shelf for a year in his damp garage. Dominator didn’t rust at all.
Part of learning from the Internet is understanding which morons you need to listen to
Here is the sds for the Castrol....Both are made by Lubrication Technologies. The question is whether they are the same oil. I am having trouble finding the correct SDS sheet for Castrol to compare them. Interestingly, though, the Castrol JASO certificate number is suspiciously close to numbers held by Husqvarna. Maybe it is blue for a reason?
Yeah I'm aware that the addition of gas and combustion is going to change things but if nobody else has a issue running it that's good enough for me.With no combustion byproducts present that doesn't tell you the whole story.
Actually air cooled two cycle oils dont have dedicated rust inhibitor packages. They contain some calcium or magnesium based detergent that does have some buffering capacity to neutralize combustion by product acids. I wouldn't trust any of them for more than 6 months in a damp climate. Ester oils like like K2, Dominator, R50, etc are particularly less robust at corrosion protection. This is because they use ester base oils. Esters have great biodegradability, which means they breakdown in the presence of air and water. This property also makes them less robust at protecting from corrosion.It has a rust inhibitor package just like the others, but it doesn’t have a fuel stabilizer. That came straight from an email to Amsoil
Regardless of oil used a guy shoukd use fogging oil when storing s two cycle. Its cheap, available st Walmart and takes seconds to fog chainsaw. After having expensive motor rust on me years ago I started using it and have ever since with perfect results.
I dont know if that's true or not.I have heard that synthetics don't cling as well in stored saws. Is that true also, or is it primarily the biodegradability that is the issue?
Not that it matters if you fog before storage, but I was just curious.
Most guys yard stick on oil is their machine they run relatively little didnt blow up..Yeah I'm aware that the addition of gas and combustion is going to change things but if nobody else has a issue running it that's good enough for me.
I wasn't even aware fogging was a thing until you mentioned it. I'll definitely be getting a can.Most guys yard sti k on oil is there machine they run relatively little didnt blow up..
Severe corrosion will cause failure. Light corrosion my or may not and you have to inspect to know for certain.
I never knew my sleds crank was corroded until I tore into it to re ring.
Fogging before storage takes seconds and is the easy route in all this....hint hint.
I use it on all my stuff both 2 and 4 cycle when I put it away for the year.
I use this stuff. Walmart stocks it.
Give it a few squirts short of stalling it, then give a long squirt until the engine stops spinning. I think this method is much better than spraying into the plug hole, which won't get the upper and lower rob bearings or the entire cylinder. Alot of it ends up in the exhaust port when using that method.Do you spray it intermittently and then finally kill it with the spray or shut it off and take the plug out and give it a few squirts ?
Idk what stabil smells like but I've used amsoils fogging spray for quite a while on my mower and pressure washer and I think it smells good when I start them again in the spring.
