jakethesnake
I Am The Snake
2:37 AM
Here & Now
A couple of mine *s-word off on me if I don’t give it a lil. I don’t like leaving them on high idle. The 2 series has the throttle lock and yeah that starts them wide open so kinda just enough to help me keep going. After warm they idle fine
mainer_in_ak
10:37 PM
Interior Alaska
Tuned the neighbors milling saw at 12,500 rpm. It was filled with 32:1 of my lucas/90 octane mix.
We double checked things in the cut. It was an 18 ft long cut in a 16 inch wide spruce slab. After the cut I put a tach on it while it was warm: 11,500 rpms. His fuel mix is 24:1 lucas. Checed air filter, it was clean.
What is actually causing a saw to loose rpms between the different mix ratios?
whitesnake
2:37 AM
NY
A richer mix ratio has less fuel. But I wouldn’t think that change would make that much of a difference but I could be wrong. Lots of variables man!
Partner
8:37 AM
Poland
I liked red bulls testing also. However I haven’t seen any lately.
What I did take from eggs tests was some oil is just good. Yes it has flaws but. Some info could be taken in my opinion.
When I start a saw I have a couple that need to be “blipped” sorta hit the throttle. Not make unnecessary noise but just enough to keep ‘em running. Start the first cut a little on the gentle side Then give it to her good. Kinda like… yeah never mind 😂
I also believe that moderate cutting of trees with a cold engine is better than idling
mainer_in_ak
10:37 PM
Interior Alaska
Having been an Echo/Shindaiwa dealer for the past 15 years I can honestly say that my customers running Red Armor at 50:1 or 40:1 (what I personally recommend) have very few to no oil or carbon related failures.
I don't care for red armor:
1.Exhaust fumes smell like sht.
2. It's insanely expensive and there's only a single place that carries it: home depot fairbanks.
3. Rarely is it stock
4. In below zero weather, the crank residual turn to the consistency of bubble gum, making the larger cc saws extremely hard to start.
Running a fleet of 2 stroke stuff: ice auger, snowmobiles, trimer, brush cutter, saws, I'm not going to put the saws on a special wittle boutique oil. Gawd I get tired of hearing about echo red armor.
What is up with these echo goobers, they're everywhere! (Just joking bud)
Price, availability, and compatibility across a fleet, injector or pre mix. Those are my priorities. Even if my saws sounded like a fkn baby rattle at 3-4 years time, I still wouldn't switch to red armor.
Onan18
OPE Sponsor
2:37 AM
Georgia
Well I am an Echo/Shindaiwa Signature Elite dealer so...
Sorry you do not have a good Echo dealer near you, I always have Red Armor in stock and am less than half the price of what the local H.D. sells it for.
The box store wants $7.97 for the same 2.6 oz. bottle that I sell for $2.95 :eeeeek:
As far as the smell and getting thick at cold weather I cannot personally attest as it hardly ever gets below 40°F here in Dixie.
mainer_in_ak
10:37 PM
Interior Alaska
Yep. I use it for everything that sits for more than a month. 2 or 4 cycle.
Jzus cripes yer getting old. When a man starts fogging his engines, it is time for a mid life crisis.
CR 500 with port work and pipe??
A young honey thats down for anything and doesn't give a fk?
Maybe both?
jakethesnake
I Am The Snake
2:37 AM
Here & Now
Red armor is a *b-word when it’s cold. You are correct. I use it. It was the blend of the month a few years ago. I bought a gallon for 65$ maybe a little high but I wasn’t too upset about it
I’m not a red armor fan boy. I just use whatever. I do like it ok though. Would recommend it to a friend.
Ran husqvarna low smoke for a good while. Kawasaki, benol (hated it) raisman full synthetic
bwalker
2:37 AM
Montana
Maybe both?
I love a good cr500. Sold my last one during covid for a stupid price.
Firewood Hoarder
Just a firewood hack
1:37 AM
Wisconsin
I always wanted to build one into a supermoto. Saw a street legal CR500 built on an aluminum frame and plated in Michigan, and then registered in Wisconsin.
Practical? No
Tons of fun? For sure
bwalker
2:37 AM
Montana
Practical? No
When I moved from Michigan to Montana the DMV asked me if ai wanted to plate my CR500 AF and Yamaha Banshee. Of course I said yes.
Anything is street legal here with minimal fuss.
As for a 500 on the street. If your wringing it out often your hands will go numb...
rogue60
4:37 PM
AU
The majority of the testing was at 100:1, 200:1, and 300:1. Later tests went straight to 300:1.
Probably the single biggest takeaway is viscosity literally means nothing. The add pack is what makes or breaks an oil. Amsoil Dominator is a very thin oil, in fact it is the lowest viscosity oil that placed first in the testing.
Actually the latest testing on viscosity in the real world is pointing towards it's very important. Apart from a thicker oil has a better ring seal and producing measurable hp gains, thicker oil also offers superior engine wear protection over thin oils.
There are companies with all the expensive equipment and knowledge testing all this.
Testing also shows once an engine is up to operating temperature any parasitic loss of a thicker oil goes away.
I believe top fuelers run a straight 70-80 weight oil. Whoever said viscosity means nothing is guessing at best lol
2:37 AM
It still depends on the ad pack. I believe it was mentioned that dominator has a lower viscosity than most oils tested, but it was the one that came out on top because of how clean it runs even with added heat. But generally speaking, if the ad packs were the same, I agree completely with you
