Cut4fun
Redneck Chainsaw Repair
1:08 PM
Ohio
About Oil injection Oils and Smoking - It's important to understand that there is no such thing as a "straight petroleum" oil, nor a "synthetic" oil.... those are just industry "buzz" words. With the exception of castor bean oils, all 2stroke oils are a mixture of the chemical components needed to do the respective job at hand .... and it has been that way for many decades. In the 70's a very common component of most 2stroke oils was "bright stock". Bright stock was very inexpensive, and offered decent lubrication qualities, but it contributed greatly to excessive smoking, no matter how lean the oil ratios got.
Nowadays, most "quality" two stroke oils have long since replaced bright-stock with Poly-Butane. Poly-butane is roughly triple the cost of bright-stock, but it smokes much less, and still offers great lubrication qualities. All that said, there are still several 2stroke oil makers that use bright-stock instead of Poly-butane ... simply to cut costs. The bummer is that there is no labeling that allows you to know which is being used, and very few oil makers that will give you an honest answer if you ask them. This same scenario applies for several other primary components of current 2stroke oils. But There's more.....
99% of all two-stroke oils containers say "smokeless" or "low smoke". The truth is that there is no engineering nor industry standards for varying levels of "smoke-free-ness". The oil makers can print anything they want on the bottles without ever having to meet or comply with any industry standards or limits.
As a result of all this, we use exclusively Maxima Oils products, because the folks at Maxima are very open and up-front about what their oils are made of. In the genre of Maxima 2cycle oils, their 927 castor oil is by far the best for high-temperature competition engines. However if you try to use this castor oil in a street (premix) application, you can experience excessive smoking in engines that do not run particularly hot. The most smoke-free oil that Maxima makes is their "Super M" which comes in a premix and oil-injection viscosity. Super M contains no bright-stock, and instead uses the much more smoke free poly-butane. Maxima also offers a purpose made "scooter" oil that is slightly more smoke free than Super M, however this scooter oils doesn't offer the lubrication needed for a high temperature air-cooled vintage engine.
Piston Seizure Vs Piston Scoring - Piston “seizure” and piston “scoring” are two different stages of the same problem. When the oil film on a cylinder is momentarily burned or brushed away, the bare metal surfaces of the piston and the cylinder wall will actually touch. When this happens, there is a sort of scraping that takes place between them. If the oil film is quickly resumed, the marks from this scraping will often remain on the piston and (or) the cylinder wall. A momentary scraping or "scoring" seldom causes any permanent or performance robbing damage. In a momentary scoring event like this, no significant damage takes place because the oil film is resumed before the piston and cylinder have a chance to start exchanging material onto one another.
Scoring is commonly seen on the piston face directly below the piston ring end gaps. The blast of combustion can get between the large end gap of a worn out ring and burn the oil off the piston and cylinder in that area...Hence the surface scoring. In most cases, score marks can simply be sanded off of the piston and cylinder. However when ever you see scoring, it's a good idea to find the source so that it doesn't develop into a full blown seizure.
Piston seizure is a case of scoring where the oil film does not immediately return. After a few moments of constant scoring, the piston and cylinder will scratch each other hard enough to remove material from each other. This floating material grinds itself into the piston and the cylinder as it continues to grow in size. As this snowballing material grows, it will drive the opposite side of the piston against the cylinder wall with a pressure so terrific that scoring on the other side of the piston begins to take place. While all this is going on, your engine is still running wonderfully at full throttle. However if there is a momentary lifting of the throttle, the force of this scoring can cause the piston to “seize” in the bore. In a “light seizure” event like this, the rings often escape any damage, and the engine will easily re-fire as soon as the engine cools down slightly.
The death blow of a “power-on” seizure comes when the mass of material between the piston and the cylinder wall finds it's way to the piston rings. This nearly molten mixture of aluminum and iron can lock the ring in it's groove. This ring locking, not the piston surface scoring, is what actually causes your engine to quit when you experience a “throttle-on” seizure. When the piston ring becomes locked back in it's groove, it's incapable of providing compression sealing against the cylinder wall. This instant loss of compression, while the engine is at speed, causes a dramatic loss of power. That power loss, along with the added drag of the badly scoring piston, makes the engine quit or lock up in a nanosecond. In fact this entire seizure process, from the first scoring scratch to the piston locked solid, takes less than a second at full rpm. In such a failure, a single cylinder
bwalker
1:08 PM
Montana
Lots of information. Most of its pretty decent and some even pertains to saws.
Redbull661
661 hoarder (BlueBallz)
12:08 PM
MN
ok ran 3-4 tanks of honda hp2 in the Arctic 661. Wanted to see how that would look vs the klotz original techniplate.
here is the klotz original techniplate vid 7 tanks at 36:1 -
here is same saw after 3-4 tanks of honda hp2 at 36:1 -
junkman
Crush it
10:08 AM
pacific northwest
The hp2 looks better of the 2 ,question on the 661 ,is the rod supposed to have that notch on the top by the bearing ? Looks like it is chipped ? or is it a spot for oil to get to the bearing ?
Cut4fun
1:08 PM
Ohio
Is this 661 after you put the updated boot on?
Redbull661
12:08 PM
MN
yup. next will run schaeffers to see how much it cleans things up. Then back to klotz orig tech...you guys name the ratio I should use on the klotz.
I'm getting pretty fast at taking this thing down and putting it back together. So I don't mind.
Cut4fun
1:08 PM
Ohio
Looks like she is running normal now.
Wonder why they put that first style of boot in the first run. Horrible idea IMO. Washers that come loose and cause a blockage in the intake.
1:08 PM
Wasn't the original design without the washers sucking the boot in? The washers were there to prevent that. The updated thicker boot should've been on the saw before it hit the market. Seems kinda hinky to have rubber washers floating around inside the intake boot. I'm sure Stihl wishes they did it right the first time
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:08 PM
Provencal, Louisiana
Looks good! By looking at the top of the piston what made u say it burn better technically than kl200?
jmssaws
Banneded
12:08 PM
If it had a better filtration system it would have never had boot problems.
Think about how restricted it would have to be to suck the boot shut. Rediculous really.
bwalker
1:08 PM
Montana
Looked cleaner to me and more residual...even though that's a product of ratio and operating conditions prior to shut down.
Keith Gandy
12:08 PM
Do u not want a coating of carbon on top of the piston or not? Havent we said if the crown is clean its too rich or the oil isnt combusting? Theres an awful lot of contradicting in this thread
stihl saws
You can always justify another saw.
1:08 PM
Virginia
Anyone have any specs on where Bel-ray MC-1 and Maxima Super M fall in Redbull's cool chart?
Keith Gandy
12:08 PM
klotz top of piston = very wet and black which can easily be rubbed off with finger and rag. IMO It's not burning fully efficiently.
honda - shows transfer wash and nice thin dry carbon on top. To me that is burning fully and efficiently.
Look i'll be honest here. This goes back to what I was saying back on arboristsite. 2 stroke oils have different properties and will thus run differently then others at the same ratio.
Also goes back to what I was saying about H1R and 800 on arboristsite. They are very pure, have high flash rates (yes i know it's not an absolute metric, BUT it is somewhat of an indicator where the stuff starts to burn) and they have high thick viscosities. Klotz orig techniplate holds these characteristics as well.
Meaning with normal chainsaw cutting I don't think they run optimally at 32 36 maybe even 40:1. Need something like 42 45 or maybe even 50:1.
btw - Honda has a very very nice viscosity (relative to others) for protection but starts to burn off at 225F vs Klotz at 460F
Same list of 2t oil. left side is sorted by visc , right side sorted by flash pt. (lowest to highest)
I would take viscosity rating over flash point in choosing an oil but thats my opinion. Redbull what is the flashpoint actually indicating of the oil ? Do u think that makes a difference in performance/protection in saws?
bwalker
1:08 PM
Montana
The original techniplate had a coating of greasy crud on it. Probaly from incomplete combustion due to running rich with the washers in the intake.
bwalker
1:08 PM
Montana
HP2 appears to be building a layer of carbon in a decent wash pattern as it should. Way to early to say. Run it for a few years and you will know for certain how it does over a variety of conditions.
bwalker
1:08 PM
Montana
Then you would be making a huge mistake. Flash point is nearly worthless for telling anything of value.
Notice there are no high viscosity oils that actually are Jaso FD certified?
junkman
Crush it
10:08 AM
pacific northwest
All that cert means in my opinion ,is one company has deeper pockets than the other ,they have to pay to have that on their bottle i believe.
