What? No bandsaw milling threads?
Sawdust Man
Manufacturer of Sawdust
9:45 PM
MO USA
is it effective time efficient?
i feel like it would be time consuming….
It is time consuming, but well worth it on suspected logs....the trouble is deciding which logs to suspect.....I often hit iron in places I wouldn't expect, such as one nail 10' + up the tree on "woods" trees, with no outward indicators.
Chief Cat Herder
9:45 PM
I'm sure I've posted this before, but the worst damage I ever did to a saw chain was by sawing into a 3/8" chain. The bad thing is that I was the one who put that piece of chain in the crotch of that willow tree 20 years prior. When I broke up the crotch and recovered the chain, I remembered losing it and having to cut myself another length of chain to pull engines with.
Crzybowhntr
Apprentice Slacker
10:45 PM
WV
So, I've had my mill set up in my garage for a few weeks but haven't used it bc I need to get my sawmill shed built. I'm having trouble making up my mind on how to go about clear spanning 20' for the area I want to roll my logs into. I'm thinking about a 5.5"x12"x20' white oak beam or a prefabbed floor truss. Any input or pics of how you guys accomplished this?
10:45 PM
if you dont do the beam like i told you ill cut up the mill when you go out of town the next time
Chief Cat Herder
9:45 PM
Just build a truss.
Sawdust Man
9:45 PM
MO USA
Yep, build a truss....or if you have a big enough log cut a beam like you said, that size white oak would span that no problem..... assuming there are no gigantic knots in it.
Crzybowhntr
Apprentice Slacker
10:45 PM
WV
Just build a truss.
Because I'm dense and want to do this right the first time, by 'truss' you mean a single appropriately sized floor truss style to span the 20', correct?
