- 6:00 PM
- Jan 8, 2016
- Farmington, CT
All good and best of luck!
I meant w/o the can. Have to use the can to get it in either waywell, you might pop it, you might not. I can prove that with using the coke can method you don't pop it out. up to the OP which way he does it.
I popped the seals out on mine. Heated the fw inner race for 10 seconds and slid the crank in. Used longer bolts to pull the other side in. Reinstalled seals later on.
If you try installing the clutch side over the stepped crank with the seal in place, you'll pop the spring out like Matt said.
By popping the seal out, I meant removing it. Then reinstalling later
I reused mine. I got in there at the right angle and popped the big one out. Made a tiny dent on the outside. Tapped the dent out with a hammer. The small one I tapped out front the inside.Thanks Kev, I wasn't sure about removing and reinstalling the same seals. I'm guessing use a little sealant around the outside for good measure when reinstalling ?
Worth a shot, I might give that a try. I have extra seals just in case, but if I can make the old ones work I'm all for it. I will of course pressure/vac test after it's done.I reused mine. I got in there at the right angle and popped the big one out. Made a tiny dent on the outside. Tapped the dent out with a hammer. The small one I tapped out front the inside.
I only did it to see if it was possible. If it leaked, I'd just replace them.
So it is possible
That was exactly my approachWorth a shot, I might give that a try. I have extra seals just in case, but if I can make the old ones work I'm all for it. I will of course pressure/vac test after it's done.
