backhoelover
I like tools
- 6:16 AM
- Feb 10, 2016
- lincolnton nc
Some of the hand tools i use. View attachment 10872 View attachment 10873 View attachment 10874 View attachment 10875 View attachment 10876
Two gauges, leak down tester. Used on 4mix engines. One of the tools i dont use. Not a fan of the 4mix.With your Stihl vac and pressure set, what is that part of the kit for with two gauge's for?
Also, what is the fixture that is right above the barbed outlet of the vac/pressure tester?
.tools informations hereWith your Stihl vac and pressure set, what is that part of the kit for with two gauge's for?
How do you find the genuine Stihl seal puller do you find it worth the price you paid for it and does it work well on other saw seals
I love that tool more accurate than a business card
work 99% perfect in all saws not only stihlsHow do you find the genuine Stihl seal puller do you find it worth the price you paid for it and does it work well on other saw seals
I have one on order a little pricey not to phased as long as it works really wellwhere it really shines is in small seals like a 200t or an 026 where there isn't a lot of "meat" for a screw to grab to. having the different "jaws" that come with it makes it a more effective tool for the differing models/uses. its not cheap, but makes you wanna pull more seals because of its cost....which is pretty much the right thing to so when a battered saw lands on yer bench
That's nice, I have yet to have a business card let me down.I love that tool more accurate than a business card
By the way, those are made of 4340 alloy steel not cold rolled.Best tool ever! Never be able to do the Dolly's without it. [emoji3]
What is it for?
Thanks, it reminds me of what the pig is holding.That is a puller. Jack bolt in the center and handle to hold on to.
