Tools for saw work
Genius
First member of ASlite to receive a infraction
9:29 PM
Uncle Willys basement
d.l.d
8:29 PM
Arkansas
With your Stihl vac and pressure set, what is that part of the kit for with two gauge's for?
Also, what is the fixture that is right above the barbed outlet of the vac/pressure tester?
Two gauges, leak down tester. Used on 4mix engines. One of the tools i dont use. Not a fan of the 4mix.
The fixture, a test flange for the ms171, ms211. I assume the 181 also but i haven't put my hands on one so i dont want to give false info. Most of what i mess with comes in a box that to most people looks like trash. And is usually a 0 beginning or end saw20160213_221731.jpg 20160213_221719.jpg .
panteliss
3:29 AM
Europe
tools informations here
Stihl working Hard
Is it Friday yet
9:29 AM
Perth Australia
How do you find the genuine Stihl seal puller do you find it worth the price you paid for it and does it work well on other saw seals
angelo c
Coal Member
9:29 PM
where it really shines is in small seals like a 200t or an 026 where there isn't a lot of "meat" for a screw to grab to. having the different "jaws" that come with it makes it a more effective tool for the differing models/uses. its not cheap, but makes you wanna pull more seals because of its cost....which is pretty much the right thing to so when a battered saw lands on yer bench
Stihl working Hard
Is it Friday yet
9:29 AM
Perth Australia
I have one on order a little pricey not to phased as long as it works really well
