- 12:07 PM
- Mar 14, 2017
- Illinois
really really check around the water pump, the weep hole is hard to see, put a piece of cardboard under the truck at night and see where the leak is.
the 5.3 and 6.0 motors are the easiest v-8 head gaskets to get to, the intake doesnt have a water jacket, I have had a few ls motor apart and it only takes me about 2 hours to have the cylinder heads off.
sparkplug inspection should show which cylinder is getting coolant in it, better fix it before antifreeze gets into the oil and main bearings.
Yes could be a water pump weep hole but going off.....
............My Silverado’s coolant leak is getting worse… getting into the exhaust
Not yet. Still runs amazing. I’ve gone thru 1 1/4 gallons of coolant in the past 2 months. Sometimes it takes 1.5 weeks for the low coolant light to come on, or sometimes it’s close to when yesterday it only took one day! Oil is clean and remains same level or goes down. No leaks seen on ground or engine bay. Exhaust is almost alway clear except yesterday it was white idling on a warm evening after replacing fuel pump. My dad says run it until it pops head gasket unless I have the money to fix it before then. If I don’t have the money to fix it when it pops I’ll borrow his 95’ gmc Sierra until I get it fixed, gonna be a lot of time and money.
I am still thinking a head gasket but heck pray before you pay.
Fill her with silver seal and see.
