- 4:38 PM
- Jan 14, 2016
- North western Ohio
I've only got one sleeved engine which is a Mac125 C .I made and fitted the cylinder using a Lisle precisian hone to factory specs using grade 50 cast iron .Which I might mention is the same alloy Harley Davidson used on iron cylinders . It's been so long ago I have forgotten exactly how the compression was on basically a new engine .Since then,maybe15 17 years I have not ran that saw enough to even seat in the piston rings .In this portion of Ohio it's seldom you find a tree large enough to put a load on that big old redwood slayer .Too danged heavy to cut fire wood with unless you are 25 years old which is half a century ago for me .This spring I hope to fire up all my 100 plus cc saws just to blow the cob webs out so to speak .
