- 10:45 PM
- Nov 24, 2023
- Northern Idaho, Ehh
Yeh, big chain hotel at something Google calls Tishman Airport Center
Would these have been cast offs or would this have been considered a project cylinder for the die-hard enthusiast to finish up before using?Unfinished saw block. It has a sleeve but is otherwise unfinished.
I know of a few kart guys that would order unfinished blocks so they could set their own timing and port shapes. Some of the dealers did this as well for the custom saws being built in the late 60's through the late 70's. The cranks I don't know about although there were a few guys ordering roughly-finished cranks to make stroker kits out of.Would these have been cast offs or would this have been considered a project cylinder for the die-hard enthusiast to finish up before using?
The crankshaft is on its way here now. I tried contacting the seller to see if they would make a package deal but no reply, hopefully no one will jump in on the unfinished block and I will get that one here as well.
Mark
That is cool to know!! Well beyond what I can do, but cool to know otherwise!I know of a few kart guys that would order unfinished blocks so they could set their own timing and port shapes. Some of the dealers did this as well for the custom saws being built in the late 60's through the late 70's.
Yes Oregon sells both small and standard rim sprocket drums.Question for the yellow saw people...On a 700 I want to replace the clutch drum with the large spline type to accommodate an 8T rim. Is there an aftermarket drum that would work?
