Yukon Stihl
- 11:16 PM
- Jan 11, 2016
- Great White North
SameOrganization of any way, shape or form is not in my DNA.
Ur first one , is one of the best ones .1st time McCulloch owner, Pro Mac 850, couldn't believe it fueled it and it fird off easily and runs good.
Is it missing a muffler cover of some sort?
Will not affect operation at all. Just not 100% correct. Use a good oil mix at 32:1 in the saw. They are chrome bore, the cylinders and pistons are ultra rare and basically non exsitant anymore. So 32:1 is important for the longevity of the saw.I knew something didn't look right, and now you mentioned it, I can see where the clutch cover has been cut, I do appreciate the info.
I like the grey and yellow, it looks kinda steam punkish to meI prefer a 16" on the 10-10 models, maybe 18" on a PM55 or 10-10S version. I have everything you need except the clutch cover/brake assembly and I may have a decent used one of those; I will try to remember and look next time I'm up in the attic.
More progress on the 1225 yesterday, engine is fully assembled and we have a good strong spark. I ended up swapping the shroud from a 5-49 in the attic as the one that was on the saw was badly bent up. This one actually has some paint left on it. You really must assemble these in the correct sequence and be careful with all of the "captive" nuts behind the screws. Many of the nuts are no longer captive and like to fall out before you can get the screws installed. I did use some glue on a few, including the bolts for the recoil starter. The shroud goes on first, then fuel tank, then flywheel housing, then the starter pawls & screen, then the starter itself. Not. perhaps. the best planning on the part of the engineering team at McCulloch in the late 1940's.
Mark
I've been looking into McCulloch two man saws...The transmission (gear box) is back together.
1225 1948-1948 7.9 In3
5-49 1949-1951 7.9 In3
7-55 1951-1953 9.8 In3
99 1954-1963 9.8 In3
1-92 1961-1962 6.3 In3
1-93 1962-1963 6.3 In3
940 1969-1971 6.3 In3
4 down, 3 to go
Mark
BrianI've been looking into McCulloch two man saws...
4 down, 3 to go
Mark
Great info mark.... Please share further discovery if you can.
I'm trying to make heads or tails of these saws as well..... Thanks to help from Chance Wold, I have many of the components including transmission shims made made. So far I have a 1225 with the smaller carb casting, and the 7-55 with the larger carb body, and the D shaped diaphragm gasket (24945). It appears from your earlier post about the diaphragms that they may have been more of a mix and match but if I can, I'd like to establish a standard (X goes with Y). Right now its all on visual inspection, and it would be more clear if we could define what came with what... The IPL I have has not been clear. It covers several saw versions but is vague when it comes to the diaphragm types. Most other differences are made clear however. Guessing it was early for McCulloch so IPL's were not as standardized as they eventually became.
Brian
So much for consolidation of versions Eh?Brian
The the #18199 has the vent in the cover.
The #24945 does not but on the rare occasion there is a #18199 that does not as I've had to exchange a few for a couple of customers. There was also one occasion where a a #24945 had one, according to a customer, I can't confirm that just did an exchange.
Jeff
That isn't a box to throw away is it? That would be a sad day!First time tearing down an older McCulloch today.
Nah. So far so good.That isn't a box to throw away is it? That would be a sad day!
Definitely differently built than a 2100!!Nah. So far so good.
I have one of each size and most of a 99I've been looking into McCulloch two man saws...
4 down, 3 to go
Mark
Brian
