Squareground3691
- 3:23 AM
- May 1, 2021
- New England
Looks really good!850 , new gaskets, rebuilt carb, and a reconditioned original Mac bar , she runs real good,
Those are really great looking!!! I am not happy that I don't have a McCulloch yet to match those. I will be watching to see what you come up with for the older 10-10s as I do have two of those saws. I have the metal plate for my 200 and it has the embossed "McCulloch 200", unfortunately it is pretty banged up. I am looking for a 3D printer that I can make a positive and negative for and press my own. I saw a guy do it for his motorcycle and it turned out really good.Should be the best reproduction available as far as looking correct.
Very niceFor all you 125 aficionado's I have finally made up reproduction stickers for the Super Pro 125, and 125C saws.
https://www.oldsawshop.com/McCulloch-Super-Pro-125-Stickers-c178373878
I also am working on some 10 series early style stickers. Some are very accurate but the really early style I'm making are not embossed like the originals. These are run but need to be cut....Hopefully sometime this next week.
I'm trying to figure out what chain is needed on a ProMac 510 (37.7cc saw).
Pic of the bar.
From what I'm finding it appears to be 79DL's @ 0.050 , but I'm not sure regarding the rest of the specs.
I am guessing 3/8 low profile chain. You can measure between three rivets and divide by 2 and find out.From what I'm finding it appears to be 79DL's @ 0.050 , but I'm not sure regarding the rest of the specs.
I didn't think about that, but it will make sense with the number of drivers and probably a 16 inch bar.I wonder if the ".250" indicates 1/4" pitch chain?
Thanks Mark for the chart..250 is 1/4" pitch chain. 91615 should use a loop with 80 DL, I have some 81's I can cut down if you need a new chain. I also have a good supply of the 1/4" pitch cloverleaf 8T drum/sprockets.
Mark
