Maintenance Chief
- 11:24 AM
- Jan 4, 2020
- South Carolina
If you were actually going to run this beast at say gtg's or such ,how hatd would it be to convert it to say a tillotson from an 090 or something?I had the 73 together last week only to discover a crack in the gearcase cover that was weeping oil.
Took the saw apart, cleaned the cover thoroughly and applied some J B Weld to the inside, back together and at least that leak was cured. Still weeps a little around the starter cover and now the primer is dripping a bit.
At least it was running again, much like before though with good top end but won't continue to run at idle.
Mark
Just wondering.
