- 4:25 PM
- Apr 13, 2020
- 5543X, 5644X
Ended up with very light weeping after sitting overnite with the replacement line. The old line left a puddle of fuel in a short time window.No sealant should be needed if the fuel line is correct for the saw. As Steve noted, a few wraps of Teflon tape will work wonders. I recently bought an AM fuel line just to see if it would work...it was so loose in the hole I tossed it aside, I'm not sure even Teflon tape would be able to fix it. When I run out of OEM lines I will continue to use grommets and Tygon, I find that is also a good solution and provide a leak proof pass through the fuel tank.
Mark
I'll remove the line again, check/clean the hole if necessary, and initially try the teflon tape wrap.
Thanks for the suggestions.
