- 8:22 PM
- Jan 14, 2016
- North western Ohio
I have no idea when the atom bomb was built or why they bypassed the points .They anchored that gizmo in place with some type epoxy ,might as well have used chewing gum because it kept rattling loose which broke off the wires .For that matter the offset key might have been installed backwards retarding the timing ,not advancing it .So if it's 2.5 degrees that would be approx .23.5 degree instead of the stock 26 advance .All I know is with the points ignition plus the key it runs better .As for the flywheel the only way it could have been that tight was if they heated the hub and drove it in place or used an impact wrench on it .That thing is one of those old school Clydesdales ,doesn't see much action .I once spent 4 hours running that thing with a 48" bar, wore me out and I was a lot younger then .
