edju1958
- 11:40 PM
- May 23, 2018
- Western N.Y.
I had the 610 sitting in the toasty house all day while I worked on it & the warmth must've slightly dissolved the old hardened oil.I took the saw out to put kerosene in the tank,but couldn't locate the kerosene,so I just put winter grade oil in it & began pumping.I could hear the air bubbles at the bar pad as the pump primed.Lo & behold it's oiling just fine with the manual oiler.I didn't have the saw running because there was no bar or chain on it.I'll do that tomorrow & get some pics on here.
The recoil is a different story.It sat for over 24 hrs.with Deep Creep sprayed in & on it & it's still stuck fairly tight.I'll have my son use his drill/driver on it to try to break the big screw loose that holds the pulley on.This way I can have a look at the spring to see what's going on.
